Aluminum heads 2004 Escalade 6.0?
95escahoe
Does a 2004 Escalade with the 6.0 have aluminum heads?
adventurenali92
Big Bear Lake, ca
So would I need to worry about the castech heads with the LQ4 6.0 in my 2006 Denali xl? Still learning about this motor and I'm concerned about that problem with all I've read about it.
95escahoe
95escahoe
@SnowDrifter , not sure on the casting number as I haven't opened them up. @95escahoe , I thought the same on the 4.8 and 5.3 but I wasn't sure.
It's on the exterior of the head. Found this on the driver side above the exhaust manifold, close to the firewall.
rockola1971
Indiana (formerly IL)
The number can be found on the front lower corner of the passenger side head and since the heads can be swapped passenger to driver side and vice versa the number can be found on the driver side head on the far right corner lower side. Its not uncommon for grime to get there and cover the number up. Passenger side is the easiest to see. Ive seen LS engines with 2 heads with cast numbers that didnt match each other.
Durobans
