93blkongreenpro
- Joined
- Feb 9, 2016
- Posts
- 1,388
- Reaction score
- 1,358
I need to pull mine out and get the dremel
Sent from my SM-G935P using Tapatalk
The idatalink lets you connect to the odb port and see certain features from the vehicle. Th gm5 is the specific harness needed for the nnbs. For $129, it sounds like they are getting you the harness that retains chimes, steerig wheel controls and on star. The idatalink and gm5 harness retail is about $200 for both, so BB is not providing that.Sooo many questions about this. OK, so get the scoche kit. What is this idatalink you guys are referring to along with this GM5? I went to Best Buy and they recommended this expensive harness kit for like 129 that gives plug and play for radio and also steering wheel. Its supposed to retain everything. I want to be fully prepared for this. What are these things you guys are using?
If you dont care for on-star and dont have bose, there is a cheaper harness.
Doors open, check engine codes, you can clear the check engine codes, you can see all the gauges, tb position, speed, intake temp, etc etc, backup sensors on screen, tire pressure, load, all that fun stuff. You cannot see oil pressure. Ill take pictures later if i remember.I definitely dont care about on-star but I do have Bose, just not the one with the speaker in the middle. I'm very curious on the features you can see regarding ODB. I wish someone had a video of all this stuff. Definitely appreciate the feedback
The idatalink is the brain. The GM5 is the specific harness for the nnbs.That sounds hot! So the GM5 alone allows you to see all this detail?
Car FeaturesI definitely dont care about on-star but I do have Bose, just not the one with the speaker in the middle. I'm very curious on the features you can see regarding ODB. I wish someone had a video of all this stuff. Definitely appreciate the feedback
The harness that comes with the mastreo is not needed. Thats why the GM5 harness is required. Every vehicle has a specific harness.I am guessing these are the 2 harnesses that are needed.
http://www.crutchfield.com/p_794ADSMRR/iDatalink-Maestro-ADS-MRR-Interface-Module.html
http://www.crutchfield.com/p_794HRRGM5/iDatalink-ADS-HRN-RR-GM5-Interface-Harness.html
You are correct thats what I used when I installed a nex8200 in my 2007 HoeI am guessing these are the 2 harnesses that are needed.
Yep. I am tracking. You need both of those. Shouldnt have said both harnesses as the first link is the maestro unit itself with a generic harness. 2nd link is the nnbs specific harness that retains all major functions.
For some reason i thought i had read that the vehicle functions wouldnt work with our Tahoes. I am stoked now that i found this thread. Cant wait to get my 8200 installed.
I haven't yet. I never understood crutchfields position on why it wouldn't fit. They said it was because the screen pivots down and out but when I explained that my factory nav does that already they just said we'll try it then. Kind of poor service but oh well. From reading though it just seems like light sanding of the dash kit allows everything to work just fine. I hope to have it installed soon. I am trying to figure out which double din kit looks and fits the best. Seems like there are great and horrible reviews of every kit out there. Lol
And I am piecing my own install kit together through eBay.
It doesnt technically fit. I have to grab the bottom lip of the screen to get it to slide down and push it to get it to go back up.Did you ever get the 8200 installed?
I ran across this thread while doing some searching to see if the AVIC-8200NEX would fit in my 2010 Yukon XL. Crutchfield claimed that it would not - but then I found this thread and a few others where people had done it.
I just have to pick up a few more pieces (the iDataLink Maestro, the GM5 cable, the Scosche faceplate - am I missing anything) - and then maybe I can get the unit installed next weekend.
Crutchfield has an install kit - but it doesn't look like it comes with the Maestro and it has the Metra faceplate kit.
I'm thinking I might be better piecing out the extra install pieces rather than going with the Crutchfield kit.
