MichaelSE
2010 2500
Tucson
It's been in the 20s-30s in the morning here, and it sounds like mine has developed an unfortunate case of piston slap. At least I hope it's piston slap and not something more damaging. Anyway, next oil change I'll go with Mobil 1 high mileage, which is supposed to be a bit thicker than Mobil 1 standard, and see how it sounds.
DaRosa218
The Dude abides
Modesto, California
Not everyone agrees to this however, on my 2006 I had terrible position slap. I did seafoam via PCV and it went away.
MichaelSE
2010 2500
Tucson
I'll give that a try.. which PCV did you use, the one on the airbox? And how much of the can did you suck up?
950410
Yanked the side moldings. Looks so much cleaner. Don't be fooled by the reflection off the floor in the last pic. It looks like the paint is lighter where the molding was but you really can't tell at all that they were there.
MichaelSE
2010 2500
Tucson
I disconnect the Vacuum line from the brake booster and draw it up via a dixie cup. I use a half bottle when doing it
Thanks man. Did you just stick the hose in the cup and suck it up like a straw?
Just to get back on topic for what I did to my NNBS, I downloaded a GPS speedometer app that has a 0-60 and 1/4 mile timer, tried the 0-60 timer and got a result of 7.0 seconds :D I've done it a few times and got 7.1 or 7.0 each time. Obviously it's not the most accurate measurement, it uses the iPhone's GPS antenna and counts in increments of 1/10th seconds, but it was fun to try and good to know that this big beast can still hang with most new SUVs on the road.
93blkongreenpro
So refreshing to replace the terrible h11. Jesus.
Sent from my SM-G935P using Tapatalk
07LTZJNAK
Subscribed to SiriusXM for Wifey (she still doesn't know about it), replaced a rear stoplight bulb, and purchased a replacement idler pulley since it is a little squeaky when cold, will replace that tomorrow along with some other minor cosmetic stuff.
Really dig this thing, almost hoping Wifey will hate it (not likely). Need to order the folding mirror replacement gears so I can get it done before Christmas.
JK
Fosscore
@93blkongreenpro
You have a link to the bulbs you went with? Did you have any issues getting it to clip to the OEM harness when you installed the new bulbs? I ask as I tried one set and had to send them back as they would not clip in securely. Thx man.
93blkongreenpro
@93blkongreenpro
I did a retrofit with the Morimoto Mini D2S 4.0. I used the h11 harness. XB35 ballast. Morimoto xb35 5500k bulbs. I didnt just replace the bulbs.
Fosscore
Ok man thx that info. Looks good and bright too.
93blkongreenpro
They are. Nice cutoff so all the light is on the road and not blinding others, so its a safe enjoyable experience for everyone. Theretrofitsource.com sells rebiased bulbs and the harness, so if you want a pnp kit, give them a look. The harness is 35 I think and 50 for a set of bulbs. In clearence, they have the value harness and used ballast, so you could get away for about 150 or so probably.
Fosscore
That's not bad really for a retro. Good info. Thx for me and others as well.
07LTZJNAK
Replaced driver side front exterior and interior door handles. Exterior handle was not springing back to the closed position and would stand proud about half the time. Interior handle had the sharp peeling chrome issue.
Replaced the idler pulley to get rid of a cold weather squeak up front - nice and quiet now.
LED interior kit, 12V outlet covers and rear view camera harness for the Rosen head unit should arrive at office tomorrow.
JK
JK
Dis gon' be good. You gonna shoot a reaction video when you present it to her?
Jonah52
Senor ******
Cleveland
Did my front brakes. Was able to just turn the rotors and throw some pads on. I just get the cheapies because ceramics always squeak and it drives me crazy. Also realized I had a blown cv boot so I will replace that hopefully this week. Didn't have the part or time to do it yesterday.
Drewphil
