[SOLVED] Fast blinking after Turn Signal LED bulb swap
Tom Joad
French V8 lover.
Chamonix-Mont Blanc ski resort,. France
Hi guys..
I've boughts LED bulbs for my turn signal/hazard few weeks ago.
When I replace even only 2 out of 4 bulbs I noticed that the turn signal was really fast though the hazard signal was still at normal speed.
To fix this I only had to replace the OEM thermal flasher which is set under the dash panel, with a Novita LM487 enectronic flasher.
I did the swap today and I tell you this works without adding any resistor : both hazard AND turn signal blinks at a normal rate.
https://www.amazon.com/Novita-LM487...hoe&keywords=2003+chevroelt+tahoe+led+flasher
05Single
afraid of the dark
I need to get this and throw away my ugly resistors
OhFourChevy
Houston Tx
It's a really simple install, pull your old flasher from behind the kick panel under your steering wheel, easiest way to find it, is turn on your hazards, and it'll be a large relay that buzzes when your hazards click.
Simple pull and replace, the factory one is in there pretty good, just FYI, takes a bit of pulling to get it out
05Single
afraid of the dark
Yea I was reading and someone said it was a pita to replace. I couldn't imagine it being too hard.
Tom Joad
Tom Joad
French V8 lover.
Yes, really simple.
I'll post pics this evening.
Remove the panel in front of your knees, you'll see a metal part. Behind it you'll see the OEM flasher, pull itwith a light move fron front to back then replace the LM487 there. Enjoy.
Tom Joad
Tom Joad
French V8 lover.
I bought this one :
Remove this panel (2 screws with hex head. 6 or 7 mm).
Unplug the blinker and replace with the new one :
05Single
afraid of the dark
Oh haha its literally right there. Eazy peezy
05Single
afraid of the dark
Oops sorry, sigs don't show on my poS phone
kwOH
Banned
Will this work with the resistors till i feel like taking them out?
OhFourChevy
Houston Tx
Shouldn't be an issue, I've heard with led tails you lose cruise, I know that when I switched to all LED turns, DRL, etc I did this with no resistors and everything works as it should. This was one of my first mods to my truck, the only reason I knew about it was because I did the same thing to my old F150
BadDaddy2003
