chaingun427
OBS Mad Scientist
Mooreland, OK
Found an injector swap, I've had one leaking down since I finished the swap, and picked up a sry of 30lb for $35. Easy cam and injector changes are probably the biggest benefit to an ls swap
Sent from my SAMSUNG-SM-N920A using Tapatalk
#1taho
5150TAHO
niagara falls ont
They day I bought my hoe 5 months ago.
The sexy engine i rebuilt a few months ago.
What she looks like for now.
Its not lowered yet but if everything goes threw like im hoping it does I will be ordering the 2/3 kit this weekend. It is a 1999 Chevy tahoe police package. It is two wheel drive but converted it over to 6 lug the correct way. Rebuilt the engine. Replaced the grille with one off of a GMC and was finally able to find some 2000 Chevy tahoe z71 fender flares. Next steps are lowering it, removing the ugly side steps, and getting the limited/Z71 front bumper.
The taho looks great. If you lower is go back the the other mirrors. They will look out of place. But for the look you have why not lift it ? Tow mirrors and fender flairs more of a lifted truck thing ?!
Good start to your project lookin good. Subscribed :popcorn::happy160:
Dneel81
OKC
removed old cracked dash. resurrected one from the junk yard and painted it to the new interior color. Painful with only 1 man but it's back in and looks great. First step in the many coming with the new interior.
South Carolina
Im keeping the tow mirrors. I still tow vehicles with it. I lowered it because it is 2wd.
qukon 95
i would like to have that metal covering that you parked under.
ISU-152
What I've done this summer ( I just re-sign ed up)
4 new Kumho m/t tires
Alternator twice
Skyjacker 7000 shocks
Polished
ISU-152
....and just noticed I'm missing a leaf spring mount bushing fffffff
1BADI5
DMV
Installed the Flowmastet catted y pipe and cat back.......almost a bolt on job.
I also took the opportunity to do all 4 O2 sensors since I was in there.
The drivers side exhaust manifold flange was not drilled right
1BADI5
DMV
Discovered the real coolant leak I have........my heater core YAY!
So I'm going to order a new core, heater control valve and all new hose(in bulk).
Since I have to drain some coolant off to do the intake manifold gaskets the timing is perfect. I guess better to have it happen now then in the moddle of the winter.
DaRosa218
The Dude abides
Modesto, California
Lifted the back 2" more and turned the keys up just a bit so she'll sit level, and no the keys aren't turned up all the way, wink wink...LOL. I also changed the rear diff fluid with Valvoline 75w90 and replaced the greasy diff cover for a new chrome one :)
1BADI5
DMV
I pulled everything apart to do the heater core ....... come to find out the heater core is fine.
Replaced the HVAC blower motor since I was in there.....wow, what a difference. The new VDO blower I got from AutoZone has twin ball bearing
Tomorrow is D-Day, time to do the intake manifold gaskets, Taylor VMAX intake spacer kit, valve cover gaskets, new spider and Summit Racing Distributor. Also going to do the heater control valve and new hoses.
Escalade2007
