How to do the 4 or 6 high mod on an 03-06 full size truck for $3.00
DenaliAK
Colder than you
Alaska
lol to a cop "well I was on vacation in va beach and noticed my inspection sticker was over due and me being the good law obiding citizen that I am, stopped at a local shop to have it done, thats why my sticker is from a va beach shop sir" lol.
I used to work at the DMV here, and you'd be surprised how many people tried to do exactly that...lol. "But I got an inspection in Florida!"
"That's great, but doesn't apply here. Each state has different standards. Thanks for visiting the DMV."
vatahoelt
NoVa
okay, so i ended up doing this. the 2 pack was $1.56 and it took me about 5 minutes to do. to make it easier, I flattened the ends with a hammer, which made it a lot easier to put them in with the relays.
i hope that there won't be any issues later on if i decide to take these out with the relays still fitting in there tightly.
vatahoelt
NoVa
i was thinking that i probably should have soldered the resistors inline with some 14 guage wire, which would make it super easy to put into the diode peg.
brndns_hoe
Plano, TX
i just stuck 'em in, no problem...was done in a couple minutes, no flattening, no soldering, nothing
DenaliAK
Colder than you
Alaska
$1.56?? You got ripped.....lol
Mine were $0.97 for a two-pack.
Still probably the cheapest mod either of us will ever do.
vatahoelt
NoVa
haha, yeah. i was expecting the $3 like the title said, but was happy when it wasn't. I can put the extra towards a tune. :D
gtbigup01
Columbus, GA
Ok so after reading through this, I still don't understand this mod or what it does. Does it allow you drive around with ur high beams on all the time for the 4hi and then Lows/High/Fogs on all the time for the 6Hi?
Question 1. Why would you want to ride around with ur high beam on, especially at nights? I can see the fogs but why high beam
laydout97
05'Tahoe
Millbrook, AL
From the factory your low beam lights will turn off when switched to high. This mod will keep the low beams on when you turn the high beams on. From the factory the fog lights only work when the parking lamp and low beams are on. The 6 mod allows you to keep the fogs on with the high beams. Now if you only have low beams on, high beams wont work. This mod just makes all the lights work on high.
gtbigup01
Columbus, GA
Thanks for clearing that up for, I was lost as to what this mod was about :Handshake:
BTW: welcome to the forum
laydout97
05'Tahoe
Millbrook, AL
Thanks! Ive been lurking for a few days now and decided to sign up. I did a few mods to the hoe today. White 05 LT with autoride. I debadged, painted bowtie, did the 6 hi and hidden antenna mod. These have to be the cheapest mods I have ever done to any vehicle I have owned. I think i may have spent about 3 bux on all of it...lol
1highbaldguy
So Cal
sweet. im going to have to try this.
does anyone know if its possible to do a 6 low mod? if so, how does the wiring go for the diodes?
undercover_skank
LongBeach
easiest and cheapest mod ever! did it today and it worked just fine. got the diodes from radio shack for like 1.50. thanks!
firehill
ok, sorry but maybe i missed something. Why can't the 4 high or 6 high with the diodes be done on a '02? Something different in the fuse panel?
DenaliAK
Colder than you
Alaska
I'm not sure it COULDN'T be done, just that it's even easier to ground the yellow wire. Saves you a buck or two on diodes, too.
Mine's an '03, so I don't know for sure, though.
firehill
ok, just looked at my '02 and it doesn't seem to have a seperate relay in the fuse box for the low and high been. the only one i see was labeled "HDLP" so might have to go the cheap route of grounding the yellow wire.
TnTahoe
TN
I know this is late but for the guy worried about the inspection, you could easily just take the diodes out before inspection and then just put them back afterwards
vatahoelt
NoVa
yeah, i just say f'it and put them in. i don't get inspection for another 7 months or so.
kickitandholdit
GA
i have don that under the dash but i really won those day time drining lights in the middle on too pleas let me know if it can be done thanks
ASG-MikeS
