93BlkOnGreenPro's 2007 Yukon SLT Build Thread
93blkongreenpro
93blkongreenpro
That's coming along nicely Darius! I also like how your projectors sit farther back in the bowl than mine do. I am thinking I might have to take mine apart again and bring my projector farther back. I'm getting quite a bit of light scatter coming from behind the shrouds and going to spots on the ground. Keep up the good work! I can't wait to see final pics of them installed!
The lens wasn't all the way on, so I'm sure mine will sit almost exactly like yours once the lens is completely seated. No easy way to push it back. If I went through that trouble, I would just mount the for 3.0's that are sitting in the box.
93blkongreenpro
93blkongreenpro
Received the Acme 3157 switchbacks in the mail. Now to order the "gold" ebay resistors like I have on the G5 tail lights to prevent the hyperflash.
I watched a youtube vid of a guy with a 12 silverado, and instead of wiring the resistor inline, he grounded it. I may give that a try when I pull the headlights loose. That would make it easier to mount the resistor to a metal surface.
Sent from my SM-N910P using Tapatalk
05Single
afraid of the dark
I guess they make a flasher relay for it now. Just replace your stock flasher in the fuse box with the new one and bam your done. I have no link, just read it somewhere. I remember i was mad cause I had already bought the gold resistors lol
93blkongreenpro
93blkongreenpro
I think on the nnbs, it is controlled by the bcm and not by a flasher unit. From my research, this is what I have came to the conclusion of.
Speck
Olympia, WA
That is correct. I researched for even trying to reprogram the bcm and the 07-11's cannot be reprogrammed. From 11-14 you can.
05Single
afraid of the dark
Oh snap my bad. I forgot yours is a nnbs. My bad, I was spaced out when I was commenting
Forget anything I ever say ever again lol:banghead:
93blkongreenpro
93blkongreenpro
Lol. Its okay. You got me excited for about 5 mins, then my dreams were shattered.
93blkongreenpro
93blkongreenpro
Parts arrived
Mevotech upper and lower control arms, innner and outter tire rods.
Sachs strut mounts.
AC Delco intake manifold, manifold gaskets, injector seals (top and bottom), throttle body gasket and Iridium spark plugs (truck has MSD wires already).
OEM ZW7 rear shocks.
I think I nees hubs. I wil prob go Timkin and replace both at once.
I need to find ZW7 or equivalent front struts and order rough country 2" front level kit. I have the upper strut mount lift and had to cut the studs. If I lower the front back to factory height and lower thr rear to level, I want to make that as easy as possible.
It should ride and handle better. And that shake at 75-80 should go away.
05Single
afraid of the dark
Parts arrived
Sachs strut mounts.
I just commented on this exact same pic on fb lol :rotflmao:
93blkongreenpro
93blkongreenpro
New seat backs. They are not all leather, but it looks better.
I need to take some installed pics.
Sent from my SM-N930P using Tapatalk
93blkongreenpro
93blkongreenpro
Also ordered some husky mud flaps, and they should be here Thursday
93blkongreenpro
93blkongreenpro
Mud flaps came in. 30 min install.
93blkongreenpro
93blkongreenpro
I met up with metalmaniac and got some goodies!! Man. What. A. Difference. Twice as bright. The red offest make a huge appearance difference. Classy if I dare to say.
Before:
After:
After the drop (removing the front level kit ro bring back to oem height and lowering the rear 2" to level) and doing the suspension, I might be on the something.
And getting Chevy to replace the Cats and look into my tranny whine at hwy speeds.
05Single
afraid of the dark
Not a fan of mud flaps, I have a set I put on for winter tho. But summer they stay off lol.
Also the 3rd bl came off tyf?
93blkongreenpro
93blkongreenpro
I dont love them, but I dont hate them either. As long as they serve their purpose.
Edit: yes. I got them from the classified section here from metalmaniac. 3 full led conversion esky 3rds have slipped away. I jumped on this one. And he made me a deal on the pnp esky tails and appliques.
93blkongreenpro
93blkongreenpro
The red is growing on me. I don't think the Esky came in a color close to the grey stone.
93blkongreenpro
93blkongreenpro
Small updates. Removed the front level lift and installed a rear level.
Installed a aftermarket denalu style grikk with poslished emblem.
A
Got all my suspension bits on except the lower LCA, inner tie rods, rear zw7 shocks and f&r sway bar bushing. I did get the airlift 1000's installed and plumbed.
Thats all.
My interior vinyl arrived today, and man is this stuff thin! I'll see how it goes.
And I plan on getting my retro installed next week. I just need to buckle down and get it done.
Just need to aim, wire the led resistors and seal. I need some amber t10 side marker bulbs. That should round up my Denali look for the front.
I think thats it for now.
scottd
