93blkongreenpro
6 hours? Shouldn't take more than hour to r&r.
Sent from my SM-N920V using Tapatalk
Shit breaks when I work on it. So I habe to ne careful. The GG is holding for now, so we'll see if it messes up. Chevy gave me the printed repair instructions and it seems straight forward enough.
Sent from my SM-N910P using Tapatalk
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Found a nice replacement solution for the oem metal lines. Flexible rear ac lines to replace the crappy steel lines that rot after a few years. Good news is that you don't have to remove
The old lines. I just ran them along the side of the old ones and zip tied them up.
The bad news is the old lines into the rear Evaperator and expansion valve fused together. When I tried to separate , it snapped the lines off from the Evaperator. Now I need to order and replace the expansion and evap core.
93blkongreenpro
Ordered a bunch of suspension parts, zw7 shocks and struts , spark plugs, and intake manifold w/ accompanying gaskets.
Next month, it all will be installed for the trip to TN on October. I still need to order the cat y pipe since mine are bad and different exhaust tips. Im thinking dual tips for each side. Black maybe.
dross99_si
SE Florida
Battery shit the bed on my wife tonight in a gas station parking lot. I had just got home from work and got the call. Drove over and tried to jump it with the Pilot. Wasn't happening. Drove to AutoZone and bought a battery. Then had to go home and get tools before heading back to the gas station. Swapped battery in the parking lot and life is good again.
Not the coolest thing to have to deal with the second I get home from a 12 hour day and I'm one sip of beer deep, lol.
Oh well at least we won't have to worry about battery woes for a few years now.
93blkongreenpro
Some parts arrived. Ordered the wrong front struts (zw7 nbs looks like) so I still need to find the zw7 front struts.
Intake manifold (in box) with gaskets also arrived since I broke the pcv valve.
redeknightjr
Changed brake pads and had rotors turned at the Sprocket care center on Ft. Hood. Only $8 per rotor! Pretty good deal. I paid $100 for front and rear pads, installed myself. Add $60 for rotor turning and bay time. $160 total versus $189 per axle at the dealership and Firestone. Im happy!
1SG Retired
dross99_si
SE Florida
Nice job!
Let me ask you a question: did you arbitrarily have rotors turned, or was there something obviously wrong with them?
redeknightjr
Nice job!
They were warped....the rear was pretty bad. I had the whole vehicle shutter when braking. I could also feel it in the highway at 65mph and above
1SG Retired
redeknightjr
He and Jarrad are some great guys. I will be getting an update during the Fortworth event
1SG Retired
950410
Installed trailer brakes and pulled this thing 150 miles. I was worried the 5.3 would barley move it but did much better than I thought. Averaged 8 mpg.
dross99_si
SE Florida
Nice to hear that it handled the Avenger. How hard was the brake controller install and how long is Avenger?
950410
It's considered a 27 foot but I don't know if that counts the tongue, etc? Longest thing I've ever pulled lol.
The controller install was easy. 4 wires are blunt cut under the dash - the directions of the controller tell you which color matches which. I soldered & heat shrunk as opposed to the cheap crimps that I never have liked. Then there are 2 wires that under the hood that have to be hooked to two posts on the fuse box. Why they didn't do that part at the factory I'll never know. Whole thing took less than an hour though.
wwiizz
