Emergency demolding issue
SethSwitch
Hello All,
So today I decided to take of the side molding to try to achieve a cleaner look. So I used heat and floss then gently used a 3m eraser wheel to remove the adhesive. After a while I noticed
where the adhesive was were scratches running vertically through the paint. I was surprised as i used the eraser wheel horizontally. I am wondering how to repair the scratches as well as fix the difference in color between the door and the previously covered paint. Thanks in advance for all of the suggestions. If worst comes to worst I will get either the escalade ltz or denali molding to cover it up but would like to keep it clean if possible. Thanks again.
MichaelSE
2010 2500
Tucson
It's tough to tell whether they are scratches or just really resilient adhesive. Since you already have a buffer for the eraser wheel, what I'd do is get a foam backing pad and try some Meguiars M105 compound. The M105 is aggressive but I think it will take off whatever that is. It will have to be followed with a less aggressive polish like M205 then a wax to protect the clearcoat.
STORMIN08
My guess is residue, hit it again with the eraser.
Then compound and polish.
Eman
I was thinking of demolding my ride today aswell. Now I see this and it changes my mind. Dose anyone think I should demold ?
MichaelSE
2010 2500
Tucson
I think your Yukon would look clean as hell with or without the molding. I personally like the red/chrome combo though so I'd leave them on.
STORMIN08
I like the ltz and denali moldings...when you want to change it up, grab some painted door handles !
NeverSatisfied
eBay Baller
Wichita, Kansas
Compound/polish/seal and should be good. Just looks like a dull spot from the tape. My 08 looked liked that when I demolded it until I put some work into
This was the before and after on the day I did it
Eman
Well thanks. I have thought about switching my Yukon up with black rims and all terrain tires. But I think it looks so so so clean the way it is now.
Eman
I think you bring down the rear to take away some rake and throw on some escalade running boards and it would be perfect. It's a super clean ride already and that color is beautiful
How much would it cost to bring down the back end ? And would it affect the smoothness of my ride ? And also the run in bords I got now don't look that good ? Escalade have a spefic kind your referring to ?
NeverSatisfied
eBay Baller
Wichita, Kansas
Might run 200-300 to bring down just the rear and IMO it wont change the ride at all but ppl have different opinions on that. The escalade running boards look like the factory ones but they have a chrome strip the runs down the side. Not that your currents don't look good tho
6point2lovelifers
