Z71 Step Bar/Trim fastener ID help
SUBURBIAN
All Chevy
I'm trying to remount brackets, trim and step bars on my 2003 Z71 Suburban. It looks like I may be missing some fasteners. Hopefully someone can post a part number or spec for them.
There are two holes in the bracket that line up with two holes in the underside of the rocker pan. What fastens these brackets to the rocker panel?
S
SUBURBIAN
All Chevy
Thanks for posting, 915.
The image shows the bracket as #8. The bolt #7 holds the bracket onto the inside of the rocker panel. I have those bolts; they're panhead style torx bolts about 1.5 inches long. #9 in the image is a little piece of plate material with two bolts welded through it, and it fastens the step bar onto the bottom of the bracket.
What I'm looking for may be #10, but the image does not really show where it goes or what it fastens.
Whatever these mystery fasteners are, there are 10 of them per side (2 per bracket) and they fasten #16, #1, and #8 to the underside of the rocker panel.
Do you have descriptions for all of the part numbers maybe?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
#10
GM#11561257 RIVET, DOME, 6.3DIA X 16.125, 13 OD, AL ALLOY, PLAIN (ASST STEP BRKT)
walk in price $4.50 each
seeker
