WTD: Motor Mounts for GMT800 and Gauge Cluster Needle Tool, Removal Fork
mattt
Looking for a pair of new motor mounts for a 2004. The 3 GM part numbers I'm seeing are 25828247, 15226255, & 15226251 but there could be others that would work in my application.
Looking for a gauge cluster needle removal tool, fork thing that I've seen a time or two. Need to do some gauge cluster work and the proper tool makes the job easier.
Let me know what you got, where you're at, and what you're asking.
Thank you.
Fless
Moderator
People's Republic of Colorado
Any cheap plastic trim panel tool set will have a forked tool. Use a plastic one. If you fear damaging the cluster face, put down some painter's tape before removing the needles.
M
mattt
Post the last 8 digits of your VIN, and @915_Tahoe may be able to provide you with the correct part numbers for your truck.
Thank you. My VIN ends in 4R104507. I've researched motor mounts and there are different part #'s for similar vehicles(Tahoe v Escalade) with different engines(5.3 v 6.0), even though they all should interchange. I'm swapping an LQ9 into the Tahoe referenced above, so any GM motor mount is good with me. Thanks.
Hodmjstone
