Wire on Denali to tap for power?
DenaliAK
Colder than you
Alaska
I'm trying to wire up some aux backup lights that are independent of the reverse wire to switched on and off as needed. What wire in the dash of an '03 Denali is a good source of power to tap??
Pics or diagram would be awesome. ;-)
DenaliAK
DenaliAK
Colder than you
Alaska
Come on, I know I've seen this on here, just can't seem to ever find what I want with the "search" function....
bkboatnsleds
McHenry, IL
Why not go right to the fuse panel? If its decent power draw - I'd consider running a relay.
---------- Post added at 09:31 PM ---------- Previous post was at 09:30 PM ----------
ALso the 7 pin harness has a AUX power on the plug, you could pull from there and just run a switch up to the dash..
ScottyBoy
Shreveport, La
The thick (10-12 gauge) red or red with a white stripe at the back of the drivers side dash fuse panel.
DenaliAK
DenaliAK
Colder than you
Alaska
Thanks, guys.
Not sure what the 7-pin harness is, though. I'm still an electrical novice despite my many hours of messing with headlights.....
Rivieraracing
It's the round electrical plug next to your hitch that you connect a trailer's electrical to!!
DenaliAK
DenaliAK
Colder than you
Alaska
Oh, that one.
lol
I thought we were talking about something under the dash.
So...tap that, or fuse tap? I thought there was a good power source in the ignition wires, I'm just not sure which one.......
ScottyBoy
Shreveport, La
If you want to use an ignition wire, use the thick pink wire at the fuse panel or ignition switch.
Off Road Pedia
