White smoke(coolant)
Ceejkay
Ft. Lauderdale, FL
Well got the truck starting and running good, now i have a constant stream of white smoke. smells like coolant. pulled #1 plug and it wasnt white. truck is running better than ever. where do i start?
also oil is not frothy and doesnt show signs of water, i ran it for about 15min with no change, coolant temp didnt spike or anything.
Ceejkay
Ceejkay
Ft. Lauderdale, FL
opened the radiator cap relieved the pressure, started it up a little puff of white. its been running for about 30 min drove it around the block a few times and it hasnt come back... WTF???
---------- Post added at 04:04 PM ---------- Previous post was at 04:03 PM ----------
nope all i did was water pump, starter, spider, plentium gaskets were done, cam shaft and crank shaft sensors
Ceejkay
Ceejkay
Ft. Lauderdale, FL
just got done washing the truck, so it sat off for about 30min. started it up no smoke.then check radiator no coolant loss. i know i should be okay with this but im not. there is something wrong but i cant trouble shoot it. yesterday after i did all the work i drove it around for about 2 hrs. i am just at a loss for ideas, im gonna let it sit for a few hours and see where im at. but in the meantime any ideas are appreciated.
96ProCompTahoe
IN
did you spray down the spider or anything with any kind of cleaner? this is exactly why i went ahead and did the lower intake gaskets as well.
if it was me i would go through all the plugs and check for signs of water, keep an eye on the radiator, and if nothing on the plugs i would drive it and keep an eye on it.
Ceejkay
Ceejkay
Ft. Lauderdale, FL
thanks procomp, i think ive narrowed it down to a few things; slightly warped head(s), deteriorating head gasket, or a small crack. how i came up with these conclusions you ask? well when the truck was cold i had the coolant in the exhaust, when it was warmed up nothing. so my first order of business will be to start it up tomorrow see if i have smoke, the truck will be plenty cold. If i dont get smoke i will call it good and monitor it. If smoke occurs the valve covers will come of and do a head retorque. so this is my starting point, it will be a few days before im completed with these steps due to wanting to tq the heads when they are cold
Ceejkay
Ceejkay
Ft. Lauderdale, FL
ok so the truck sat off for a full 24 hrs before i started it. Started it up..... NO SMOKE.. i have done alot in the last few days, cleaned a bunch of stuff, ect, ect. i dunno maybe somehow coolant got somewhere but i cant do anything if it doesnt do it more than 1 time. i will monitor it. i did how ever pulled all the plugs and none of them showed signs of water ingestion.
johnsonwillie199
