What's this part?!?
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
I was wondering what is the name/ part # of this thing there a huge problem in the rears for the 2000-2002 models because they squeak like hell but I'm pretty sure after 2003 they changed um out I'm looking for the new piece to fix this problem!!! Thanks guys!
Alex33
I think there's a how-to on fixing this. I'll search around for you.
blrmkrl83
Iowa
Have you tried spraying some lube into the moving parts? That usually quiets squeeky hinges.
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
I swear i have tried every single lube you can think of...just doesnt work not even as a short term fix...sounds horrible though
chip
Cincinnati
My only other guess would be to ask a body shop to order some new bushings for you?
BubZX
Senior Member
Waynesboro PA
you mite think im stupid but i was havin the same problem on my 02 rear doors ecspecialy the driver side. i lubed sprayed anything i could and the squeek would not go away. the problem of the squeek was not he hinges but the corner of the door rubbing on the rubber up top when u would open the door.
chauncey0337
MLT, WA
Yes this is very common.
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
yes i know this thats why they made them plastic after 03 i believe....it doesnt make any noises or anything
Kcrowe79
