JennaBear
Resident Ninja
Makes sense, we changed out my pushrods and springs with my cam. If they upgraded your springs and rods, I would think they would have gone with yellow springs?
Which ones? 910?
You might want to change out that cam as well. If it is the cam with 112LSA, that is not a real good blower cam. You want to be closer to 115LSA.
That might be what you have to change out, and possibly injectors (if you didn't already). I would change out that cam as well.
already did the injectors and those guys said the cam is supercharger friendly
Which ones? 910?
, with a blower, no Looks like the Rousch? At the moment there are no pulleys to swap out for the Rousch kits.
What are the other specs on your cam? The LS1 cams are 112LSA, so I was just going off of that.
You will be SOL on pulleys on the Rousch, unless an aftermarket company starts making them. That would have been the easiest way to make more boost, as you are probably only at 3.4"?
Interesting cam selection.
I would be interested in seeing where they get the pulleys from, as there are a ton of folks on pt.net itching to get a smaller pulley for the Rousch. They are also stuck on there, so you would have ti figure out a way to get it off.
??To each their own.
