What I've Done To My Yukon Denali The Past 18 Months
donjetman
Bought our 2007 in Oct of 2018 w/130k miles, used car lot, no mx records for $10,500 including TTL. I did all of the following because we LOVE the way it drives/rides, and we need it to be reliable transportation when making the 1k mile drive ea way between our homes. We now have 157k miles on it. I've done 100% of the labor.
Stuff that was broke, or has broke, and was fixed:
Rear main seal & cover – Dorman 635-518 - $43
Brake pedal stop light switch - SL1000 - $19
Gas cap – ACDelco GT330 - $19
Vapor cannister purge valve on intake – ACDelco# 214-1680 - $18
Trans cooler line 1 – ACDelco 15779543 - $16
Trans cooler lines 2 – ACDelco 25999420 - $56
Trans cooler clips- ACDelco# 24205103 - $10
Trans cooler gasket - $7
Front lower plastic cowl - $31
Valve cover driverside – GM# 12570427 - $117
Oil pan gasket – GM# 12612350 - $36
Oil pickup o-ring – Felpro 72401 or GM 12584922 - $9
Exhaust Manifold clamp, back driver side – APDTY# 028218 - $30
Exhaust manifold clamps, frt driver side, back pass – APDTY#028253- $67
Front pass side door handle – 735-6526 - $49
Performed TSB 10-06-01-008M, solvent Gunk Motor Medic - $5
Fixed rear driver side door handle/lock adjustment - $0
Replaced rear power liftgate latch/lock mechanism-$210
Total = $742
Normal MX:
air filter, NAPA 22487 - $9
cleaned MAP sensor and throttle body - $1
brake fluid - $6
PS fluid, Amsoil ATF - $6
Frt diff gear oil w/3 pts Amsoil 75-90w - $21
Rear diff gear oil w/4.2 pts Amsoil 75-90w & gasket - $40
Transfer Case ATF w/3 pts Amsoil (ATL) ATF - $16
Transmission fluid, 10 qts, w/Dexron VI, $75
Tranny filter – PTC# F247 - $34
Cleaned old spark plugs and reinstalled - $1
3 oil changes, 7 qts, 7 qts, 11 qts - $125
3 oil filter changes - $27
1 bypass filter change - $35
3 lube jobs - $5
4 new tpms sensors, AC Delco #13598771 - $66
Install sensors - $20
Changed transfer case fluid w/3 pts Amsoil (ATL) ATF - $16
Installed new upper & lower rad hoses $70
Installed new heater hoses - $50
New 5 yr/150,000 mile coolant - $50
Rear brake job, calipers, rotors, pads, hoses - $372
Total = $1042
Preventative MX:
Torque Converter – Precision P4646 - $218
Tranny front pump seal – GM# 24237531 - $30
Tranny Input shaft seal – GM# 24219390 - $10
AFM Deflector – gm#12639759 - $8
Main serpentine belt – 6K935 - $19
tensioner - $32
idler pulley - $22
idler pulley - $16
AC belt – 4K378 - $16
tensioner - $28
Starter – 6757N - $60
Alternator (160 amp) – 8301N - $101
Frt sway bar end link poly bushings - $15
Frt sway bar bushings – Moog# K200222 - $7
Rear sway bar bushings – Moog K6408 - $8
Cleaned pass side valve cover inside and out - $2
3 UOA - $84
New water pump - $85
New 180* thermostat – Motorad# 523-180 - $29
New heater hose w/metal y fitting, Dorman# 626-553/NAPA# 827-5730-1 $37
Total = $827
Mod(s):
Catch can, line, fittings - $40
Installed an engine oil bypass filtration system - $150
New front Husky floor mats - #53101 - $86
Cool-It Thermo-Tec Express Sleeve, #14030, on both engine oil bypass filtration system hoses. - $22
New front center floor console – 22860866 - $91
6.2L emblems(4) - $25
GruvenParts metal T-connectors $80ea+ shipping and tax - $175
Dorman# 259-200 Cabin Air Filter kit - $25
Viair 1 gal oil tank, Viair# 91014(11 qt oil sump capacity now) - $55
Oil cooler, Hayden# 696 – $57
Various AN fittings, hose, and clamps - $100
Total = $826
So we have about $14k in it now. The only deferred mx problems that are the rear auto leveling shocks and compressor - $550. They've been bad since we purchased the vehicle, but since we don't tow or carry a bunch of people in it, still rides like a dream.
donjetman
donjetman
I forgot - I did a complete rear brake job last July. Replaced the calipers, rotors, hoses, and pads. $372. I have edited my original post here to reflect this.
What I didn't include, was that I've already purchased all the parts for a complete front brake job. Found a sale I couldn't pass up. But for now, the fronts have some life left in them.
BrainDead
Total = $742
Normal MX:
brake fluid - $6
3 lube jobs - $5
Total = $1042
Preventative MX:
tensioner - $32
idler pulley - $22
idler pulley - $16
tensioner - $28
3 UOA - $84
Total = $827
Mod(s):
Total = $826
Did you use the Hayden cooler for the tranny or engine oil?
If it was used for the engine did you run 3/8 line for the cooler, because I was under the impression that the stock lines were 1/2?
donjetman
donjetman
I used this Hayden cooler for an engine oil cooler and plumbed it with #6(3/8" equivalent) hose. I would have plumbed it with #4(1/4" equivalent) but the Hayden comes with 3/8" nipples. This vehicle did not come from the factory with an oil cooler. My engine oil bypass filter is the restriction in this circuit, not the size of the hose. Bypass filters do great job of filtering, but the tradeoff is they are restrictive. That is why I went with the small Hayden. The flow rate(gph) thru this circuit(cooler, oil tank, bypass) isn't high, so the small cooler should be adequate. My logic is "a little oil cooling is better than no oil cooling at all".
Our Yukon came from the factory with a trans cooler, rpo code KNP. It's not very big. If I towed, I would put a larger trans cooler on it.
Here's a link(with pics) to the cooler, oil tank, bypass filter install that I recently finished: https://www.tahoeyukonforum.com/threads/mods-because-of-social-distancing.117889/
Big Mama
Virginia
What time can you be here Saturday? I have the same rig so shouldn’t take but a few hours. @NathanJax can this be a sticky or something?
Awfiretto
I can’t believe after 2 years with this truck I missed the relatively easy retrofit for the air filter.
CRN_25
