donjetman
- Joined
- Oct 22, 2018
- Posts
- 2,005
- Reaction score
- 3,690
Bought our 2007 in Oct of 2018 w/130k miles, used car lot, no mx records for $10,500 including TTL. I did all of the following because we LOVE the way it drives/rides, and we need it to be reliable transportation when making the 1k mile drive ea way between our homes. We now have 157k miles on it. I've done 100% of the labor.
Stuff that was broke, or has broke, and was fixed:
Rear main seal & cover – Dorman 635-518 - $43
Brake pedal stop light switch - SL1000 - $19
Gas cap – ACDelco GT330 - $19
Vapor cannister purge valve on intake – ACDelco# 214-1680 - $18
Trans cooler line 1 – ACDelco 15779543 - $16
Trans cooler lines 2 – ACDelco 25999420 - $56
Trans cooler clips- ACDelco# 24205103 - $10
Trans cooler gasket - $7
Front lower plastic cowl - $31
Valve cover driverside – GM# 12570427 - $117
Oil pan gasket – GM# 12612350 - $36
Oil pickup o-ring – Felpro 72401 or GM 12584922 - $9
Exhaust Manifold clamp, back driver side – APDTY# 028218 - $30
Exhaust manifold clamps, frt driver side, back pass – APDTY#028253- $67
Front pass side door handle – 735-6526 - $49
Performed TSB 10-06-01-008M, solvent Gunk Motor Medic - $5
Fixed rear driver side door handle/lock adjustment - $0
Replaced rear power liftgate latch/lock mechanism-$210
Total = $742
Normal MX:
air filter, NAPA 22487 - $9
cleaned MAP sensor and throttle body - $1
brake fluid - $6
PS fluid, Amsoil ATF - $6
Frt diff gear oil w/3 pts Amsoil 75-90w - $21
Rear diff gear oil w/4.2 pts Amsoil 75-90w & gasket - $40
Transfer Case ATF w/3 pts Amsoil (ATL) ATF - $16
Transmission fluid, 10 qts, w/Dexron VI, $75
Tranny filter – PTC# F247 - $34
Cleaned old spark plugs and reinstalled - $1
3 oil changes, 7 qts, 7 qts, 11 qts - $125
3 oil filter changes - $27
1 bypass filter change - $35
3 lube jobs - $5
4 new tpms sensors, AC Delco #13598771 - $66
Install sensors - $20
Changed transfer case fluid w/3 pts Amsoil (ATL) ATF - $16
Preventative MX:
Torque Converter – Precision P4646 - $218
Tranny front pump seal – GM# 24237531 - $30
Tranny Input shaft seal – GM# 24219390 - $10
AFM Deflector – gm#12639759 - $8
Main serpentine belt – 6K935 - $19
tensioner - $32
idler pulley - $22
idler pulley - $16
AC belt – 4K378 - $16
tensioner - $28
Starter – 6757N - $60
Alternator (160 amp) – 8301N - $101
Frt sway bar end link poly bushings - $15
Frt sway bar bushings – Moog# K200222 - $7
Rear sway bar bushings – Moog K6408 - $8
Cleaned pass side valve cover inside and out - $2
3 UOA - $84
New water pump - $85
New 180* thermostat – Motorad# 523-180 - $29
New heater hose w/metal y fitting, Dorman# 626-553/NAPA# 827-5730-1 $37
Total = $827
Mod(s):
Catch can, line, fittings - $40
Installed an engine oil bypass filtration system - $150
New front Husky floor mats - #53101 - $86
Cool-It Thermo-Tec Express Sleeve, #14030, on both engine oil bypass filtration system hoses. - $22
New front center floor console – 22860866 - $91
6.2L emblems(4) - $25
GruvenParts metal T-connectors $80ea+ shipping and tax - $175
Dorman# 259-200 Cabin Air Filter kit - $25
Viair 1 gal oil tank, Viair# 91014(11 qt oil sump capacity now) - $55
Oil cooler, Hayden# 696 – $57
Various AN fittings, hose, and clamps - $100
Total = $826
So we have about $14k in it now. The only deferred mx problems that are the rear auto leveling shocks and compressor - $550. They've been bad since we purchased the vehicle, but since we don't tow or carry a bunch of people in it, still rides like a dream.
Total = $742
Normal MX:
brake fluid - $6
3 lube jobs - $5
Installed new upper & lower rad hoses $70
Installed new heater hoses - $50
New 5 yr/150,000 mile coolant - $50
Rear brake job, calipers, rotors, pads, hoses - $372
Total = $1042Installed new heater hoses - $50
Preventative MX:
tensioner - $32
idler pulley - $22
idler pulley - $16
tensioner - $28
3 UOA - $84
Total = $827
Mod(s):
Total = $826
