What is this connector/wire?
ls1frc
Going over my 6.2 junkyard motor and found this. Appears to be spliced into a 3 prong power connector?
Doesn't look factory and from what I can see on my existing 2012 5.3, this isn't on the block.
unknown-connection-1.jpg unknown-connection-2.jpg unknown-connection-3.jpg unknown-connection-4.jpg
L
ls1frc
Engine is from Montana so that makes sense! I need to research how to take it off and block it now. I suppose I could just remove the connector and leave it on too.
It's in a freeze out plug? You could always yank it completely out and put in another plug--or do like you said and just remove the connector.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Tony beat me to it. Does look like a block heater. IMO, if that engine is going to be put in your rig, I would change out all freeze/welch plugs.
mikeyss
Longmont, Colorado.
My L9H has this, it's the block heater. In my opinion, I'd let the heater stay where it is and lose the connector unless you would want to use it in the future. It's nice to have a block heater in cold winter areas.
L
ls1frc
Cool, I do live in PA and we do have winters sometimes where an entire month will be 0
Maybe I will just keep it then.
Tony you crack me up! Was it the mountain over to yer left or was it that mountain all
The way ova der!!!
HA! I literally lived on a mountain in the, down an actual dirt road in the Poconos. It wasn't a huge mountain, but I did have to go up a mountain to go home. I lived in E. Burg for around 5-6 yrs, and I still worked in Newark. Helluva commute. Many a time I drove home in the snow where I was pushing the snow with my bumper because it was so high--and it was cold AF. Didn't mind the cold tho...
97audia4
is that on the passenger side or drivers side? If my L9H has it I may use it in here if winter is bad this year.
Derick
Indy Suburbs
I put a block heater in my v6 2002 explorer some years ago. Stop laughing. It goes under the topic of "why not?" If I can just run an extension cord out and leave it on until I use the thing, and it starts easier and warms up faster, then sure its worth the 20 bucks I paid for it. Yeah it was a freeze plug heater, but worked great. A lot of places say to stick it on a timer. So, what I did was programmed a manual timer off/on every 4 hours. You'll burn it out if it's on 24/7.
The 6.2’s didn’t come with factory block heaters? I was deciphering the RPO’s on my 6.0 and saw it had one from the factory so I went out and found it. I have never used it though.
wjburken
Eastern Iowa
None of mine did. Can’t say that I’ve ever wished I had one.
MonteJ
