What bulbs are people using to replace the DRL bulbs? LED?
OneofFew
Talullah Falls, Ga
Both of mine are burnt out and I noticed there are 2 filaments... someone used the wrong bulb... I read a TSB (see below) that recommends an updated bulb, but I feel I may a swell use an LED. Is there a recommended source? part #?
Bulletin No.: 00-08-42-010A
Date: June 20, 2003
INFORMATION
Subject:
Daytime Running Lamp (DRL) Bulb Replacement
Models:
2002-2003 Cadillac Escalade, Escalade EXT
2003 Cadillac Escalade ESV
1999-2003 Chevrolet Silverado Pickup Models
2000-2003 Chevrolet Tahoe, Suburban
2002-2003 Chevrolet Avalanche
1999-2003 GMC Sierra Pickup Models
2000-2003 GMC Yukon, Yukon XL
2001-2003 GMC Denali, Denali XL
Supercede:
This bulletin is being revised to add model information and to announce availability of new DRL bulb part number.
Please discard Corporate Bulletin Number 00-08-42-010 (Section 08 - Body and Accessories).
A new 14 volt DRL bulb, PIN 15199562 (trade bulb # 4114K), is now available for use whenever a DRL lamp bulb on the above listed vehicles requires replacement. This more robust, higher voltage DRL bulb replaces P/N 1999482 (trade bulb #.4157K). These bulbs should be replaced in pairs for customer satisfaction.
Fless
Moderator
People's Republic of Colorado
@OneofFew, not necessarily the wrong bulb. The owner's manual and bulb charts show the dual-filament bulb is the one to use -- for DRLs, I have no idea why. Always wondered about that, one of life's little mysteries.
08grey
Led?
Sent from my SM-G950U using Tapatalk
95escahoe
I used a 4114 LED in my DRL’s
05Single
afraid of the dark
I got ride of mine and put switch backs in my turn signal's.
Whoa welcome back buddy:happy107:
Side note, use 4114 halogen or led. Can be found at any local parts store. Learned the hard way with my Silverado, went through 2 pairs of 3157 LEDs when I finally did some research and found out the correct bulb.
OneofFew
OneofFew
Talullah Falls, Ga
Fless
Moderator
I don't quite understand that. The incandescent 4114 (which is the OEM DRL bulb) is a higher wattage bulb by about 5 watts than the 3157, so it produces more heat, no?
EDIT: do you think the LEDs put out more heat than an OEM incandescent?
HiHoeSilver
Away!
Chicago
Heat comes from resistance, and the 4114 is a rough service (long life) bulb with a heavier filament and therefore less resistance, I believe.
08grey
I put 3157 led switchbacks in that spot. My signal lights are in that spot also. Is that not the same for you guys?
eric woods
I've been using these JDM ASTAR 10W LEDs in my Yukon XL since January of 2017, and I love them http://a.co/ihsLIZg
I have a video in this post showing what they look like if you are interested.
Agreed on the JDM ASTARs. Very versatile bulb and looks more like the Halogen headlights than the the traditional incandescents. With these in the DRL and backup lights, the vehicle is also very well lit at night when approaching and unlocking. I put a smaller version in my fogs as well.
Phlipnstik
