Modded
That Guy
- Joined
- May 3, 2009
- Posts
- 6,942
- Reaction score
- 107
Good question.
35 PSI.
For the record, I ran 37-39 in my 295/35/24. If I had 22s I would run 36 or 37.
---------- Post added at 06:27 PM ---------- Previous post was at 06:15 PM ----------
http://www.nittotire.com/Tire/nt420s#size
Look at this chart for example. The largest 24 inch size has a smaller load rating than the largest 20 inch size, both at 50 PSI.
This means the 24" wheel needs a higher pressure to achieve what the 20" tire achieves at a lower pressure.
This chart also means that, on the same vehicle, the 24 inch tire needs to be pumped more than the 20 inch tire to have a normal tread-ground contact width, while the 20 can be pumped less.
Kapish?
