Weird Grinding noise when hitting the brakes hard
Sublime69
Whenever I hit the brakes REALLY hard in my 08 LTZ I get a very loud grinding noise. Its hard to tell where its coming from I if I had to guess I would say its the rear. The pads are almost new and everything looks great when I took it apart. Any ideas???
Thanks
eohat12
Chattaroy WA
Thanks
There is a possibility you have a rock that has got wedged around the caliper , I'd pull it apart and see whats what before a rotor gets toasted
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
What area do you live in? In My area New England, rust builds up on caliper brackets, edges or rotors, inside the hats for the ebrakes. Also I’ve seen when calipers wernt tightened down and caliper bolts fell out. When applying the brakes, the caliper would move from the bracket and contact the inside of the rim.
S
Sublime69
I live in Chicago, I will inspect everything and see what I find.
XEALOT
Northern MI
I would also look at the parking break shoes. NNBS parking brakes are notorious for coming loose and making noises in the rear. I just had my passenger parking brake shoe adjusted. At 45MPH+ it made the same sound as a bad U Joint.
varminpoolteam
