water in pass floor
Tokyolow81
Hey board,
This is my first post. I just picked up a 99 Yukon and it has this same problem. I noticed it seemed to be leaking from a crack in the foam housing around the hose under the fan blower. Don't know how water is getting in there though. I guess what I'm wondering is if, yeah I know this is an old post, but did the OP ever find the problem? Thanks.
oldsalt
Hey board,
Welcome to the forum.
Haven't looked under thee in a while so I don't remember 'foam housing'.
Having said that I would make sure the drain is clear. The hose drips right on the frame on the passenger side at the firewall. You'll see the rust where it drips. Otherwise you can take off the trim covering the air intake and check the sealant around the air intake.(see photos on page 1 of the thread.)
dfrom216
95 tahoe water leak on passenger floor
i know its a old thread but i just had the same problem with water on the passenger side floor in my 2 dr 95 tahoe,i found out that under the hood in the corners by the hinges on the hood itself are 2 foam water absorbers,mine was missing so i put a few layers of weather stripping there and no more water,hope this helps.
Drewphil
