Underhood moldings and covers
Fauxnali
Gold Member
Edmonton Alberta Canada
Not sure where to post this;
What kind of prep work and paint would you use to paint the intake cover and the air cleaner cover etc... I'm not sure what kind of paint will stick to that plastic and what kind of prep work it would take to make it last. I've searched allot and Ive seen some pictures but no how to's
stevek
Dallas, TX
Use sand paper to scuff it up, spray paint it... you should take off the insides of anything such as the inside of the filter box, and the inside of the intake cover.
Apply probably 3 coats. I'll assume you don't know how to spray paint, so just do thin even coats... it'll dry faster and look better. After that I would do 2 coats of high temp clear coat
puckhead
CO
It doesn't say much about prep in that thread just that he used Krylon plastic paint. Any suggestions ?
my bad, thought it might have helped more. You can sand/buff a bit like stevek said. I have also heard wash your pieces with a degrease dish soap. Hope it works out for you! dont forget those pics!
dps
The prep work for all plastic is pretty much the same whether it's an interior, exterior, or underhood part. The biggest problem most people have is adhesion; the plastic either has to have a chemical etch to get a good bond, or a physical etch (sanding scratches).
Start by cleaning the piece in a succession of solvents; the first one should be water and detergent like Dawn. Next should be mineral spirits. I finish up with denatured alcohol. Use lots of paper towels or rags, and keep going until they're coming up clean.
I will usually give a final wipe with lacquer thinner, but be careful in that some plastics will soften with that. (Sorry, I don't know which ones do and which don't.) If you want to keep the existing texture of the piece, your final step is to spray on some adhesion promoter such as Bulldog, and follow its directions for recoating.
If you want to smooth a textured piece, you can wet sand it with something like 400 grit and finish up with some 600 grit.
If you already have a piece that is factory smooth, you can help adhesion by roughing it up with some 600 or 800 grit. I would still use an adhesion promotor spray next.
Following the a/p spray, follow with a plastic primer or primer surfacer. Primer only if you're trying to keep the existing texture, primer-surfacer if you're going for a smooth final appearance. P-surfacer can be built up fairly thickly and wet sanded with 600 - 2000 grit papers to get a glassy surface before applying color coats.
For final coats, there are any number of brands that will work; I'm assuming you're using spray cans as opposed to custom mixed automotive paints for spraying. The cans will usually say for plastics on them. This really just means they're more flexible, because you're actually painting the primed surface (the primer), not plastic. These color coats may or may not need to be clear-coated, depending on what kind of paint it is and what kind of final gloss level you want.
For example, if you're using a basecoat/clearcoat system, you will spray the base color of your choosing and then follow it up with a clear coat in the gloss level of your choice. Instructions are on the can for drying or "flash" time between coats.
In other cases you may choose a color that only comes in gloss, but you want a final finish of satin or matte, and will have to spray a clear coat over the color coat. In this case you want to make sure the products are compatible, and spray a scrap object ahead of the real project; there's nothing more discouraging than watching all your work bubble up and craze on what you thought would be the final coat!
You can get expert results with just spray cans if you take your time; there are two things to do. Multiple thin coats instead of a few thick ones. And adequate dry times between coats before re-coating, sanding, or applying the next layer of paint.
puckhead
CO
Thanks for the info Dave! Im sure it will help alot of people!
Fauxnali
Fauxnali
Gold Member
Well here's what has worked to this point. I tried a number of things on some scrap pieces of plastic (I had some spray bomb lids laying a round) and tried a few test pieces with that. The paint I used was the same as the other post, Krylon Fusion for Plastic, and I used TPS Heavy duty cleaner/degreaser paint prep wash, and cleaned it with that and then rinsed with water as per the instructions and then let it air dry. I then went with very thin coats and added a coat every 5 minutes or so until it was nice and white. I did not add a clear coat as I wasn't sure how that would stand up with the Krylon plastic paint as far as compatibility. I will have a couple of before and after pics. I'm still not done as I would like to highlight the Vortec symbol (I taped it off so the relief would stay black) and do the intake pipe and air cleaner housing as well.
Fauxnali
Fauxnali
Gold Member
Here's some pics before and after the intake and fuse box cover were painted.
puckhead
CO
wow! really like how that turned out, you gonna try and do some more pieces in there? Its still too cold here to paint, guess i could bring it inside but I dont have room or vents
Fauxnali
Fauxnali
Gold Member
I don't have a CAI so I may do the air-filter box and the piping as well. It'll be tough to get in between all the grooves in the piping though.
stevek
Dallas, TX
Just hang it from something and do really really thin coats of rattlecan... it won't be too bad.
Fauxnali
Fauxnali
Gold Member
Her's the final product with the air-box and the piping done. I left the mass air and the rubber flex hose alone.
zach2011
Platinum Member
That looks really cool! Nice job! If I didn't have black I'd do this. I might get a carbon fiber one. But yours looks really sweet.
Fauxnali
Fauxnali
Gold Member
Thanks man, you should have seen the kid at the service bay when i got my oil changed. He was grinning from ear to ear.
My wife just laughed and said "I can't wait to show all the ladies in the parking lot at the grocery store". She sees no reason to do it but at least has a sense of humor about it. LOL!!!
puckhead
CO
Nice dude! So no clear coat huh? Is that paint high temp by chance? If not are you worried about the heat at all? Just curious for when I pull all my pieces off
dizhai
