Tune up opinions
92__silverado
Alright guys it seems like the new Tahoe I just bought could use a little help. Runs good but it seems the gas mileage is a bit on the low side, even for a 4wd Tahoe. I am thinking a tune up is in order.
I priced AC Delco plugs at 7 bucks a piece, not terrible, but the delco wires are 90 dollars! That seemed high to me but I guess when you think about it its not bad over 100k mile span.
What is everyone else using for their tune up.
With plugs, wires, air filter, and anit seize i am over 200 dollars for a simple tune up.
Yikes.
blueflamed03
Oklahoma
yep, tune up on these are way more than the old cap/rotor/plugs and wires on older trucks. How many miles? I say for sure keep with AC Delco or NGK plugs, don't read into that E3 mentaility, that you'll gain more power for all that added cash outlay.
92__silverado
About 97K. I noticed a lot of guys using NGK plugs over delcos. I know they are around 5-6$ less than the delcos. Any harm in doing that, i have always done delco plugs in my other chevys. What about plug wires. recommend the delco plug wires? I don't mind spending a little extra to do it right the fist time but if there is an alternative that is just as good for cheaper i am down for that too.
92__silverado
Well after reading a few hundred threads on here and FSC, I am going with all delco parts for plugs and wires. New pcv valve, and a decent cheap paper filter since I plan to get a CAI before i need to replace this one.
---------- Post added at 04:51 PM ---------- Previous post was at 02:52 PM ----------
Well no one has the delco wires in stock so its a waiting game until tomorrow. I almost went with Borg wires but they had to order those too so I am just going to get the delcos.
92__silverado
yea this is my first new vehicle like this. 60 for plugs and 90 for wires. Ouch. They wires on there look stock, so this should be worth it. The air filter was really dirty too, looks like it had not been changed in a few oil changes.
Can anyone confirm for me that 03 was the year GM went from a pcv valve to fixed capture orifice device. I keep hearing 04 and 03 I bought a pcv valve but I haven't tried to put it on. I won't have time to look until tomorrow to see if i have one.
Thanks
TheFuzz
Idiot Police
Spurbury, VT
Good choice on the all-OEM Delco stuff. Thats all I use, and the Yuke has 116K on the clock. Runs like a swiss watch.
Might I also suggest some Seafoam, and while you're in there you might as well do the TB coolant bypass mod and pull the TB off to give it a good cleaning and get all of the gunk out of it.
You should see a noticeable increase in responsiveness and a little boost in mileage when you're done.
92__silverado
i actually am running a can of seafoam through the tank right now. i dont know how comfortable i am taking the intake off.
what is the coolant bypass mod and what does it accomplish?
TheFuzz
Idiot Police
Spurbury, VT
You don't have to take the intake off to clean it with the seafoam. With the truck running, pull the brake booster line, or the PCV line off of the driver's side valve cover, and slowly pour the seafoam into the line. It gets sucked into the intake manifold and cylinders this way. It will make the truck cough and sputter a little, this is normal. After you've run about 2/3 of the seafoam into the intake, turn the truck off and let it sit for 30 minutes. After that, start it up and go drive the piss out of it - you'll be billowing white smoke out for a few minutes though so it's best to do this at night or in a rural area. Try to take it on the interstate if you can. The white smoke is all of the carbon desposits burning off, so higher speeds/RPMs help drive the particulates out. Drive it around for 10 minutes or so and you're done. You can put the other 1/3 of the seafoam in the oil, run it a few days, and then change the oil.
As for the TB bypass - the throttle body has two lines running into it that circulate engine coolant through it. This warms the intake charge and helps the engine get up to operating temp a little faster in the winter. Those lines also make it damn near impossible to clean the throttle body because you have to disconnect them to take it off...and they're nearly impossible to disconnect. I cut them off, capped the tubes going into the throttle body, and used a barbed fitting and small worm clamps to connect the two pieces of hose together so they bypass the TB. This makes the truck take a little longer to warm up during the winter, but also keeps it cooler during the summer and keeps your IATs down. Makes it a HELL of alot easier to pull the TB off and clean it, too. Some people tout it as a "performance" modification because it keeps your IATs a little cooler, but if there are any gains to be had I sure can't tell. I did it soley to make it easier to clean the TB.
There are better write ups with pics on here somewhere, just gotta seach for em. Thats it in a nutshell though.
TheFuzz
Idiot Police
Spurbury, VT
It was a little bit more challenging in my case than the write up makes it look. I couldn't remove the hoses off of the trottle body, they were completely seized to it due to age. There is plenty of hose though, so I just squeezed the hose and felt where the fittings on the TB stopped, and cut the hose off right there. Then I made a small cut with a knife on the remaining hose stuck to the fittings, and peeled it off so that I could get the vacuum caps on snugly.
WHITEOUT
Dont Hate-Appreciate
Phoenix
Like everyone has said. Stick with AC Delco plugs. Bought those Quad platinums before, and I will tell you they sucked!! Seemed like my truck ran worse then ever. Delcos are expensive, but stick with OEM. IMO. TB mod is a waste of time, does nothing, but make it easier to remove for cleaning as previously stated. I live in AZ, and ya it "may" keep it cooler, but with all the ambient heat already in the engine bay, don't really think it matters. but since I did it, whom am I to say not to. If you were to get plug wires I would suggest MDS, is what I got, more expensive, but they are the best in the biz, so.. Ya, tuneups are expensive,but will keep that beast running for along time if you keep her happy.
92__silverado
Should be able to pick up my wires today. Being as it is near single digit temps today this may have to wait until next weekend when it is hopefully a bit warmer.
Clemsonbloz
the stock plugs that you are pulling out most likely are delco, but they are made by NGK... Those are the irridium plugs, and they are pre-gaped at .040, versus the .060 of the double platnium..
CKendrick
