BigSachsy1
- Joined
- Jan 24, 2023
- Posts
- 9
- Reaction score
- 4
I have an 05 tahoe, just put on the trucool 40k, wondering since I live in arizona would it be beneficial to bypass the radiator Trans cooler?
No id run both I have it hooked up through the radiator and trans cooler and my temps stay around 165-175 in the summertimeI have an 05 tahoe, just put on the trucool 40k, wondering since I live in arizona would it be beneficial to bypass the radiator Trans cooler?
that would kind of be like taking a step backwards, you add a cooler and then remove one....I have an 05 tahoe, just put on the trucool 40k, wondering since I live in arizona would it be beneficial to bypass the radiator Trans cooler?
Ok thank you, I was curious cause I read that some people bypass it if they live in hotter climates. I don't have a trans temp gauge but I feel like its running better, have noticed that the engine is running slightly hotter at idle.No id run both I have it hooked up through the radiator and trans cooler and my temps stay around 165-175 in the summertime
I hope I didn't mess this all up lol. Will post pics soon.that would kind of be like taking a step backwards, you add a cooler and then remove one....
Shouldn’t have messed with the engine side of the temps?Ok thank you, I was curious cause I read that some people bypass it if they live in hotter climates. I don't have a trans temp gauge but I feel like its running better, have noticed that the engine is running slightly hotter at idle.
Unless it's blocking too much of the radiatorShouldn’t have messed with the engine side of the temps?
