TruCool 40k
BigSachsy1
BigSachsy1
No id run both I have it hooked up through the radiator and trans cooler and my temps stay around 165-175 in the summertime
Ok thank you, I was curious cause I read that some people bypass it if they live in hotter climates. I don't have a trans temp gauge but I feel like its running better, have noticed that the engine is running slightly hotter at idle.
Trey Hardy
Shouldn’t have messed with the engine side of the temps?
The 40k is a great cooler my truck would stay around 205-220 and after this it’s stay around 165-175 even when I’m ******* it and when I towed the highest was maybe 185-190 pulling a truck and car trailer so that’s some cheap insurance imo for 100-150$ to help prolong your transmission life
Trey Hardy
BigSachsy1
BigSachsy1
Update: I didn't take pictures when I first finished the install a couple months ago, here they are now. Any input is appreciated
BigSachsy1
BigSachsy1
those worm clamps wil leak eventually. getting these would be better for the long term, they make it all plug-n-play tight no leaks.
View attachment 435789View attachment 435790
I didnt cut any of the metal trans lines, as you can see I just put the hoses right onto the existing ones as it seemed the ends were already flared. So plug and play is exactly what I'm going for, so thank you. Gonna order these right now
you need 2 of each
latvius
Ariton Alabama
From all the people who have had to replace their transmission because the radiator leaked coolant into the transmission side of the radiator advise you to bypass the radiator. Ask me how I know this.
have to wonder if those people purchased the cheapest radiator they could find?, normally quality issue's go hand in hand. having it happen with a oem radiator has to be quite rare
latvius
Ariton Alabama
I bought my Tahoe with 144k on it so don't know if radiator was OEM or not but it trashed a pretty new transmission when it went. We got our Yukon Denali at 100K and the radiator was leaking externally OEM or not I have no idea.
Some recommend replacing the radiator with a tranny rebuild some recommend to bypass it. It's advice take it or leave it, personally if I put in a trucool I would bypass the rad.
age and maintenance can certainly play a factor, the older a original radiator gets the less I trust it. I flush my coolant annualy, gm says it is rated to 100k but thats a load of b.s.
ivin74
05 NBS Nali
Htown, Texas
Those same folks probably didn't use coolant and used water. Water will rust the internal radiator cooler since it's made out of carbon steel.
BigSachsy1
BigSachsy1
Escalade2007
