alaska_guy
Hey everyone, I recently purchased a suburban knowing it was having some transmission based issues. Basically it has a firm/harsh 1-2 shift and the 2-3 shift flares a couple hundred rpm before it catches and holds.
It does this consistently and ALWAYS holds the gears after the shifts complete.
An online retailer/rebuilder of valve bodies suggested that more than likely, the separator plate where a check ball goes wore out due to age/use and a check ball is stuck in place causing my issues. His re-manufactured valve body kit is $200 shipped fully assembled.
Does this sound accurate? I assumed it was something valve body related since it holds gears just fine and never slips after it shifts...
Figure I am out $200 worst case scenario?
I have replaced valve bodies before so I am somewhat familiar with them and whats required. Ford 4R100 transmissions have a known issue with their feed bolts above the valve body and I have done a few of those before and fixed those, so not too scared of tearing apart the valve body.
I was looking at getting this.
https://www.kenpartintransmissionparts.com/4l60e-rebuilt-valve-body-gm-chevy-1992-to-2007/
