Transmission question
Denalibro76
I have an 03’ Yukon Denali with the LQ4 and kicking around the idea of converting to 2WD. Just wondering what transmission will work for it? Forgive me if this is a dumb question. Kind of a newbie to this stuff.
mikeyss
Longmont, Colorado.
The trans can be converted to 2WD, but the trans has to be taken completely apart. You can try and find a 2WD trans, but it has to be another 4L65 or your LQ4 will eat a 4L60 for lunch. You the would need to convert the front hubs to 2WD ones. After that, the computer may freak out not seeing the T-Case and you could run into issues with warning lights and reduced power mode.. but I'm sure that could be tuned out.
Denalibro76
Denalibro76
Ok. Yeah I didn’t know if I could just use a 2WD transmission or whatever. My 4L65 is almost shot. There’s almost 300k miles on it and the shifting is pretty lazy. A used one is surprisingly hard to come by where I’m at. Might just have to get mine rebuilt. The only reason for my idea of converting it is due to a concern with it going through CV axles. I lowered it recently and both my axles failed shortly after so I guess that brings up another question…if I put new axles on, will they fail due to the drop?
I believe that it would be more trouble and cost to you than it would be worth. Folks more knowledgeable than me on this topic are already chiming in.
Mudsport96
40.923,-89.488. Illinois
Is it currently selectable four wheel drive or is it all wheel drive?
If its selective i would just pull the cv shafts and front driveshaft and be done.
Awd poses othe issues to get around
Denalibro76
Denalibro76
It’s AWD. Can I not just separate the CV shaft and leave it in the hub? Or will the front differential and T-case just fail?
Mudsport96
I have no idea how the awd case will react. I THINK without the front end being attached there will be significant slippage in the case causing failure. Plus im not sure if there is a front shaft speed sensor to monitor traction, or if that is done through the abs.
If it is through the abs, you could maybe cheat and put a selective 4x4 case in place of the awd and keep you trans and rear shaft( 2 less things to replace).
Denalibro76
Denalibro76
Yeah I have no idea what to do. Running into more questions than answers. I’m pretty sure I’m just going to rebuild the engine and transmission. Both are on their last legs. The engine runs good but super high miles and it’s not gonna go forever.
Mudsport96
What is super high?
Mrobinson
I had gearstar build my Trans it has been awesome it is a stage 4 4l60 with a billit converter. I also use gearstar for for street rod applications check them out
bigdog9191999
sw michigan
an option would to just have a 2wd trans rebuilt ( buy a used that needs work) and just have it built to hold. may need tuning, will need a 2wd rear driveshaft, and either 2wd hubs swapped in or the outers put back in. (there is some debate on some brands, but why chance it) then just take out the front diff and such. ( not sure if the trans crossmember is the same (believe it is)
Denalibro76
Denalibro76
You can’t run an AWD transfer case without front axles or it will destroy itself. Your CV axles should be fine lowered depending on how low you are. Buy OEM or equivalent replacements.
Ok. Great to know! Thanks! It’s not a crazy drop or anything…like 3 1/2 inches in the front and 4ish in the back.
Denalibro76
Denalibro76
G
Yeah I think I’m just going to stick with what I have. Get my current transmission rebuilt and I’m good to go. Thanks for the info though!
Jmartin1026
