Trans fluid flow direction for 6L80E
dkad260
Before I make a mess, i forgot which cooler line at the radiator is in and out. I assume it enters through the bottom of the radiator and leaves through the top?
Foggy
KS
Common sense would dictate that hot enters into the top and then it cools as
it gets lower with the lower line returning the "cooler" fluid back to the trans...
I marked mine a couple years ago when i added a cooler.. But I'm not near the
yukon now to check
D
dkad260
That's what I was thinking but after a few searches I found some posts on the fluid going from bottom to top...which is why asked in the manner I did.
D
dkad260
After some more looking, I believe the bottom to top was the GMT800.
mikez71
I feel like when I did a fluid flush, that I removed the upper line to pump fluid out of radiator..
But my memory is 50/50...
If you have an external cooler, I believe it should go through radiator first?
Here it is...
Could be botton to top bleeds air bubbles better?
D
dkad260
Same...it was almost 50K ago and I'm overdue for at least a pan drop. I believe it was the top line but I wanted to be sure before I spray fluid everywhere...lol.
I think it was the upper line that I attacked a hose to.
rdezs
From the transmission it enters the lower part of the radiator tank, exits at the upper fitting on the tank and is routed to the auxiliary transmission cooler, then return to the transmission.
If in doubt follow the lower fitting on the transmission.... That's the return line.
D
dkad260
To play it safe, I hooked a hose up to the line that enters the top of the radiator, and also a hose coupler for the port in the radiator.
The fluid exited the top port of the radiator.
The fluid is darker than I expected but does not smell burnt in any way...still not a welcoming sight.
Towmaster
