"Traction Active" error code
Big Aug
I have a 2006 Yukon Denali XL. This winter, it started throwing a code that reads "Traction Active", at the same time bogging down as if the engine is dropping RPMs. This usually happens between 5-15 mph after coming to a complete stop then starting again. The code does not stay on the display, but disappears right when acceleration begins again...
Any suggestions??
wjburken
Eastern Iowa
Any suggestions??
First off, welcome to the forum from Iowa.
Do you have a scanner or code reader to see if there are any DTC codes stored?
Any work done to the Yukon prior to this happening?
How many miles are on it?
could be a couple things, possibly a wheel hub/abs sensor, could also possibly be a sensor in the transmission but a abs sensor is more likely.
normally you just get a abs light and no other adverse effects. best thing to do is to try and have it scanned while the "traction active" is lit up. with a scanner that can read abs/srs
B
Big Aug
Thanks to you both for the quick response. I had the transmission replaced (major pain) in January of 2019. Took GM a couple of tries because they originally misdiagnosed the problem and it also needed a new ECM...
I Do have a code reader, but the error ONLY shows for 3-5 seconds while the truck loses power/drops RPMs, so I don't know it.
B
Big Aug
Thanks Scotty. I’m going to take another look today and will get back with a reply
Drewphil
