I've got a 1999 Yukon Denali, its got 170k on it but has been running great since I've owned it (about 8 months).
About 4 months ago I did the following:
Spark Plugs
Wires
Dist Cap and Rotor
Fuel filter
Water Pump
Intake manifold gaskets
-while I had the intake off I cleaned the spider assembly really well with carb cleaner
Various suspension components
It ran well for months after all that.
So yesterday I was driving around and it was doing great as normal. Stopped at a gas station and got a drink, then when I started it back up it was idling very rough. I looked under the hood and cyl #3 spark plug was moving a little, so I limped it home and tightened it up. No Change.
I hooked up HP Tuners and read the codes P0300 Random misfire.
Checked all the sensors and they were hooked up, wiggled the crank position wiring as I read the wiring is a little touchy. Checked for vacuum leaks.
All yielded nothing.
So I rented a fuel pressure gauge and got the following:
Key on: 62psi
Idle:52-55psi
Blip of the throttle: bounces to 60+psi
Driving in the neighborhood and floor it I will get close to 70psi
The engine idles a little rough, then real rough around 1500rpm but smooths out over 2000rpm. Stumbles off idle accelerating.
Showing to get some knock retard when I get on it.
Sorry for the long post but this isnt my daily so I'm not in a hurry, and dont want to just start throwing parts at it.
Is this the standard "fuel pump going out" issue? If so, why is it still spiking to 70psi when I get on the throttle?
Any suggestions?
All help is much appreciated
Nick
Spark Plugs
Wires
Dist Cap and Rotor
Fuel filter
Water Pump
Key on: 62psi
Idle:52-55psi
Any suggestions?
Nick
