the real story on spark plug wires
08grey
I went oem acdelco iridium. Like 45$ for a set at rockauto
08grey
They are okay for me. Get the code. Maybe the insulator cracked on one of them when installing.
bacin87
San Francisco, Ca
The code popped on my old spark plugs/cables that's why I'm installing the new ones sorry I had to use bad language when I was explaining. The code is for the evap system and the exhaust system but both of those sensors were replaced less than a year ago all the stalling issues seem like it's just bad spark plugs I believe these are the original ones on the truck I bought my truck used.
08grey
I have never experienced the evap exhaust codes yet but Google the actual codes there are tons of threads about evap canisters and such.
Sent from my SM-G920V using Tapatalk
992dr
Eastern N.C.
Sticking with 41-110.
Has anyone tried any aftermarket wires? Specifically magnacore?
I ended up purchasing the ACDelco 9748RR Professional Spark Plug Wire Set and the
ACDelco 41-110 Professional Iridium Spark Plug I popped a check engine light and the Trucks starting to stall. They arrive on friday. How do you like the ACDelco 41-110 Professional Iridium Spark Plugs.
My 08 Denali has been stumbling a bit on acceleration when I first start it up. I initially thought it might be the transmission, but it has 82k miles and the original plugs and wires so I'm going to swap them out. Any thoughts on the ACDelco stuff so far?
bacin87
San Francisco, Ca
My acceleration has gotten better, a little better gas mileage so it was true my spark plugs were going out. The code popped again so it looks like the exhaust vent solenoids i had installed last year went luckily they had a two year warranty so when you get them replaced this month.
Jesburban
Anybody know which magnecore wires for sure on NNBS? There is contradicting info everywhere on which model #. 85241 or 85283?
992dr
Eastern N.C.
Jes,
I emailed magnacore for the correct wires for our applications. As soon as I hear back, I'll post it up.
That is as long as no one else posts up the correct info, haha.
992dr
Eastern N.C.
Copied from my e-mail
Electrosports-70 7mm cable, part number 87283 - $96.80
Electrosports-80 8mm cable, part number 80283 - $101.20
KV85 8.5mm cable, part number 85283 - $151.80
KV85 CN series 8.5mm cable, part number 83283 - $159.50
R-100 10mm cable, part number 89283 - $196.90
For shipping costs, see the bottom of this e-mail.
Our Electrosports-70 7mm (black) or Electrosports-80 8mm (blue) cables
should be fine for a standard unmodified engine, they have very
similar constructions. The KV85 Competition 8.5mm (red) cable is
intended for race or modified engines or engines with heat-related or
other problems - it is not just a bigger diameter cable. The KV85
8.5mm cable is a different product that has more capabilities for
performance, suppression and heat resistance but can be used on ANY
engine with no problems. The R-100 Racing 10mm (red) cable is similar
to the 8.5mm cable but with a thicker jacket and provides the same
performance and suppression, however it has more extreme temperature
protection and insulation.
The "CN series" cables (which are not available for some applications)
are special versions of our 8.5mm and 10mm cables that provide extra
RFI suppression and are mainly intended for ham radio, CB radio and
similar installations with unusual noise problems; the CN series
cables do not help with most other applications and take longer to
ship because CN series sets are always made to order - they are never
in stock.
Jesburban
in stock.
I also called Magnecore before you posted this, he told me I needed 85241. I gave up with Magnecore, he quoted me the same price as you, $60 more than everywhere else, I ended up going with Taylor.
jrobie79
figured I'd bump this rather than create a new thread.
I just got my 2011 escalade premium a couple months ago and I've been checking off maintenence items to have my own baseline of when stuff was done - fluids (tranny, diff, xfer case, etc), filters, belts, etc...
Next on my list is the plugs and wires. I found a smoking deal on delco iridium plugs, but I'm having a few issues with wires.
I was looking at the Taylor wires, however it appears that model years 2007-2009 have different wires than the 2010+. Does this make any sense? Specifically Taylor 84044. It comes up as fitting the earlier models, but not the later models. Anyone know for sure if this is the case?
BoiseHoe
I know this is an old thread but thought I would toss some new information out. You can find the Taylor wires on Amazon.
NASTY GM
Nor Cal
I installed the 10.4 Taylor wires, along with new NGK plugs. Seems like it woke up a little and they look cool.
petethepug
Michael
SoCal
Bringing this thread back. Nice to know about the Taylor wires. I was plagued with running issues on another one of our vehicles because of bad, hard to pinpoint ignition wire failures. Our 08 YD xl has a rough idle at start up and this may or may not cure it. Either way the truck is ready for a new set of wires after 110K on the clock.
Found the best deal on Amazon. Price was compatable with eBay and other onliners but the two day shipping was the deciding factor. I went the Taylor site that spec'd out the Taylor Cable 79206 10.4mm Wire kit for the 07 & 08 Vortec L92 Gen IV (6.2L). Make sure you go all the way into the exact product you are purchasing and you can do another very SPECIFIC vehicle search. They are $108 from factory but Amazon has them for $64 shipped free.
The link for vehicle specific product search was not easy to find. Here it is ... http://www.taylorvertex.com/product-search/
I bought these for my 03. I had to get these as I have long tubes, and they kept burning the boots on reg wires. Love Taylor wires.
petethepug
Michael
SoCal
Pulled the first plug wire off from the install on the Taylor 79206 10.4mm kit. It’s unknown when the wires were installed. Not sure if the 100k service last year replaced them. The boots had dried dielectric grease (DE) all the way down into the high tension mating surfaces.
No no no no, dielectric does not mean grease the electrical contact mating surfaces! I replaced oem GM HT leads so it’s likely they were on the truck when purchased 3 years ago. They defy do not look like they’re less than a year old. All our other cars are German I4, I5 & V6. It’s easy to DE grease the boots and keep it off all the electrical contacts.
The pass side HT lead by the firewall requires a little finesse to get in. I can see how a tech in a hurry would DE grease the boot instead of the ceramic on the plug because it’s a blind install. This appears to be what was done on every one of the plug boots. They were filled with Dried up DE grease all the way down to the contact points. If it’s silicone grease that’s BAD. DE grease (a little) ok. Silicone breaks down and coats the leads until it heats up and burns off. I only greased the HT boots on the coil end because installing the plug boots is blind. Until my intermittent engine knock at cold start is resolved, no unmarked or DE grease is going near the plugs. More to follow.
Deennoek
