TBSS to TAHOE bag set up
NORCAL SS
SUV SUSPENSION GURU
UPDATED AUG 04 2017
So you guys know it works fine and I've done many over the years.
I use the 06-09 trailblazer rear ss bag and they go right into a tahoe no problem from 00 to new 2017s. The tbss rear upper crossmember and axle brackets are the same as the fullsize suvs
Now over the years I've been doing this few extra things are needed to make it work right
1) free travel mod
2) djm rear hardware kit with bumps tops which I have for 190 shipped on my store page
3) correct rear belltech shocks which I have for 130 shipped
4) rear spoon kit with del sphere upper and lowera and includes Panhard bar with grease and del sphere tool. 675 shipped thru me. Now I've had prob 15 to 20 people bust the output shafts by not doing the arms. The rear end gets sucked forward when you drop it and driveshaft pushes into trans. Just wanted to give you that info.
Now for fittings you will need a 1/4 to 5/32 reducer. The line coming out of a trailblazer ss airbag is 5/32. Then you can hook to a 1/4 line. For those on a budget they can use any pump station to lift the back of the truck up then lower when they want to.
Also you can tow with the trailblazer 06-09 rear airbags. Ive replaced other bag set ups and tbss bags ride better period.
If you need anymore info just ask and yes it will lay the axle on the frame. People are selling these bags all the time on my trailblazer SS site for like 100 bucks.
Tahoe upper crossmember which has notches already
Tbss bag on right you can see the 3 ears that Stick up which will spin and lock it into Tahoe upper cross member
NathanJax
Vacation Nathan
Jax, Fl
Tony, do you have any pics of this set up? What is the average ride height to keep it from being too bouncy? Do you have pics of the notch you need to put for the ears?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
nope didnt take pictures im going to try to get another guys this week. Hes just looking for some used tbss bags. I sold all the sets i took out of customers trucks for a while now just didn't think many would be interested in it here but I guess you guys are.
Rear tbss bags
rear djm hardware kit
rear belltech sp shocks
You can ride 4 inch drop with no issue.
Once you get the bag in your hands you will see that you will just put in 2 sguares on the frame and the tabs will fit in it so bag doesnt move.
GWEE
Cool idea!!!!!
---------- Post added at 09:33 AM ---------- Previous post was at 08:32 AM ----------
Rear tbss bags
Being new to the SUV world what is the DJM hardware kit????
bgsdewrf
Rear tbss bags
Fearz
Houston
So basically you get the bags and stuff for around $300 and then you just have to find a system to pump them up correct?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
airlift has a few wireless systems ive used works out great for the back.
i would run the djm rear hardware kit with the short bumpstops which are 190
the bags you can get from a tbss for like 100
shocks id swap out which the belltechs work perfect
Ride height will depend on where you want it to sit. With a 3 inch drop it was about 55 lbs if i remember correctly its been a while.
Goodinblack
I Like Tacos
Dirty South
If one was to buy the airbags new..... what vehicle year should you ask for?
Any GM model part numbers?
jlx3t
give us a Write up with pics I would like these bags in the rear With the wireless airlift system
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
next truck i do i will just with the 6 inch drop springs no one really wants this anymore
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
guys are getting the 6 inch drop springs because you can drive lower on them and rides better. The tbss bags at 6 inch drop not much air in the bags. At normal ride height the tbss airbags are a 3 inch drop on a 00-13 tahoe now if you dont care about riding a 4/3 drop then go for it but many guys like the truck to sit almost even and you can do this with the tbss bags but if the rear is set at 6 inch drop it bottoms out a lot.
a4edwin
ny
do the reg trailblazer ones work also aswell as the saab ones?
HeavyHoe03
