Tapping noise w/ spark plug pulsating
GMT800 2005 Tahoe Z71
Navy Supporting Member
I was able to open it and that is what I saw. You had the plug wire boot on the end of the plug but the plug had backed out and compression was causing the plug to rattle/move on the threads and you saw the plug wire boot shaking because of that. Take the plug out and clean the threads and put anti seize on the threads and reinstall....snuggly and then reattach the plug wire. Best to do the other 7 the same way. Whoever installed those plugs, did it wrong. If was you, bite the bullet and correct the problem. Good luck.
All that was the source of your noise as well. That compression hammering on that plug when it is loose, can damage the threads in the heads.
P
PierceHaney
Thanks much for your reply. Unfortunately the threads in the head are stripped I think. New plug won’t thread back in tight. Any thoughts on that? Is it a bad idea to use a thread chaser on that ? Thanks!
Mudsport96
40.923,-89.488. Illinois
Time to hit the junkyard it sounds like. Find a truck that has been rolled or in a wreck of some sort, that way you know it was running before it ended up there. Hell i have a spare set on the shelf in my garage just in case lol.
Speaking of spare set of heads on the shelf. I was always told by a machinist friend of mine, that when storing heads, to always stand on end and never lay them down flat. Is that still "a thing"?
Lmao that plug was dancing all around in that video. If you see that when you start an engine, shut it off before that plug becomes a missile. SMH.
BadDaddy2003
