Tail Lights..... Show em
jimweis
Lancaster, PA
adventurenali92
Big Bear Lake, ca
Did the Esky full length tail lights and liked them, but were super bright and a bit annoying. I see now they have them available smoked/darkened out.
Switched to some smoked LED with U bar type design. Match my headlights better.
Will add pics in a minute
Pic of the headlights
Night pics
I need to put some tint on that 3rd brake light lens
The smoked U bar style LED tails you out on look fantastic! And I agree they match the headlights perfectly! I like them a lot! I like them so much better than the esky style tails. I am probably the only one that’s got this opinion but I don’t like the esky tail lights at all and I don’t like them even more on the older gen trucks.
PG01
Up here to the right
I'm guessing those are the smoked version? how do they look compared to the oem 2015+ lights? I'm worried I pick up a set and they look cheap compared to oem
They actually don’t look all that different (cheap) than 2015’s. Yes smoked. They are spyder brand.... at least the box said so. They are a solid made light imo. Hope that helps.
Edit: trying to find current pics but I guess I don’t have any, these are from jan 2018 but they still look good on my truck.
adventurenali92
Big Bear Lake, ca
This is my third different set , Vipmotoz off eBay
View attachment 264805 View attachment 264806 View attachment 264807
Double check to make sure those have resistors wired in properly for the brake lights, does your cruise control function properly? I had a set of those of the same brand, left and ride side functioned diffidently from each other for brake and turn signal operation, the resistors for brake light circuits were not done correctly so my cruise control would not function. I ended up having to return them.
iggyM
