Tahoe pulling right even after new in/out tie rods, new tires, and alignment
AN292
Still pulling to the right just like the day I bought it without those things I just replaced.
Any ideas?
New equipment is maybe 2-3 months old and it doesn't pull anymore than usual under braking either
My carfax says it has been in an accident before but I dont know the details on that, something bent down there?
mb1500
Got the spec sheet from the alignment?
AN292
AN292
Nah I tossed it, everything was in the green though. I saw the before and it was a significant improvement but no different in the pull
wildcatgoal
Old cars have stuck brakes. Mine pulled. I went to a race car shop to get an alignment done as good as can be done. Still pulled.
They said check the brakes. The rear passenger was stuck clamping down. Rebuilt the calipers. No pull other than what my oversized tires cause.
AN292
AN292
Find a new shop. If you took it in with a complaint of steering pull and they returned it the same way they’re incompetent.
Or its something else making it pull. They are a good shop
ks03
Fool Excess Member
Does it pull rolling 5-10mph across a parking lot? Or does it not really start until +25mph
VR4Play
I would start with doing as George said and swap the front tires left to right. Sometimes it will fix it sometimes it will go the other way. If it has torsion bars on the front you may have to have them checked to make sure they are even. Corner weights can affect pulling one way or the other.
livingez_123
Sandy, OR
Being in the green is close enough for most shops. Unless you know what specs you want it set for you get what you get. I've know my alignment guy for many years and we always talk about what I want. He is a firm believer that being in the green is not good enough. Your vehicle is simply following the crown of the road.
BG1988
Check the tire pressures as well
do you hear any squeaking from a Wheel Bearing?
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
This^
My suggestion about swapping the front wheels was an attempt to eliminate or identify a tire pull. If it still pulls then it needs a tweak to the alignment.
Big Mama
Virginia
As stated above check your brakes for a stuck caliper. It’ll be the one on the opposite side of the pull. You’ll notice how much thinner the pads are.
JPeter
