Tahoe 2015 front shock bypass conversion
SandroLR
Hi
Already did the conversion on my 2015 tahoe
Change the magnetic front shocks (whit sensor) and put a pair of blistein.
I can’t fin the by pass kit to turn off lights on my dash about this.
If anyone know where can I find it I would thanks you so much
You need to install resistors on the wires that you removed from the Magneride shocks, to fool your truck's electronic control systems into thinking that the Magneride shocks are still in place. You can get them at any location that sells Magneride bypass kits.
Be sure to retain the original electrical connectors that you cut off, in order to install the resistors, just in case that you want to go back to Magneride shocks in the future. Some of those electrical connectors are very expensive to replace at the dealer, and hard to find anywhere else.
fiatdale
Houstons Best
Houston
shocksims.com The old resistor method from 07-14 doesnt work on the 15-20.
Paul_Kaos
Can I ask an absolutely ridiculous question?
Is the magride computer independent? Like the old quadrasteer? Or is it baked into the engine PCM? my brain wants to see chassis items as separate, but I know newer stuff is running the auto trans with the powertrain computer as well so...
Jerryrich0806
Want to change the ppv struts for factory struts will that come with the Bypass Resistors? Would that work or does the ppv has regular struts
maxandpj
