Strange noise
Num12005
I have a 05 ppv tahoe,it was a texas trooper truck.It has the hydroboost brake setup (if that matters).I have a humming noise from 30- 50mph.Its very noticeable,i have checked all accesories for bad bearings,thougt it was tge alternator but after rebuild,its the same.Any ideas?It almost sounds like a mechanical fan but i have electrics.The noise is def from engine bay.It comes in around 30mph and goes away at 60mph but then its a high pitch whine.While its the loudest i can change the sound with throttle,put it in neutral (while its doing it) and it goes away.Im stumped!Maybe its something with the hydroboost setup????
Zigger21
North Dakota
when you slow down does it whine like a hmm hmm hmm
Num12005
Num12005
yes ,but it is quiet while slowing down,it only makes tge noise under load.
SnowDrifter
Sasquatch Country
Could be differential noise. How does the fluid look?
You mentioned it's quiet while gliding. What if you turn the wheel side to side as a sort of slalom?
Is the noise closer related to engine speed or wheel speed?
Do you have auto 4wd on? Or are you set in 2wd?
Num12005
Num12005
its a 2wd,the rear end is a 3.73 posi and is quiet.Its definately coming from the front,under tge hood..It sounds like a differential whine but from the front. The power steering has a little tiny bit of whine,barely can hear it.The hyroboost setup is the only thing i can think of tgat it may be.Or water pump ,maybe idler pully?Ill post a vid
02Lightning
Pull the belt and drive it, see if it goes away. Be careful, it will get hot fast.
Num12005
Num12005
Heres a vid,dont mind the shot,i was driving.You can hear it pretty good
Mudsport96
40.923,-89.488. Illinois
j_jerry79
