stolen stereo help!!!
VicYukon
Stockton, ca
What's up guys so about a month ago my stereo got stolen from my 1996 GMC Yukon 4dr. 4x4. Well I replaced it right away I didn't cut any factory wires I bought an adopter. The point is that all the speakers work except for my back passenger doors. Does anyone know what it might be? Please help.!
Donnie Yukonie
Yates Caretaker
I have the same issue , I believe the problem is the Factory AMP under the seat. I know mines fried from mudding .
Did you have to rewire a new unit in?
GMCYukonDriver
CA
Hey Don. What years had a factory amp? I didn't know they came with them until a couple months ago, so I don't know if I have one wasting space in my truck somewhere. Is it under the rear seat? Or was it a different year or option?
I have a big plastic cover under the 60 portion of my 60/40 in the back that covers the jack and other tire changing stuff, but I didn't think there was anything else in there.
used97
Hook up the remote turn on the speakers should work and check all the fuses
Fishin757
VA Beach
99s got it right. its the amp under your seat but what you want to do is take the pink wire from the factory harness and cut it far enough back to put a butt connector on it then take a piece of wire and the other part of pink wire twist them together and connect it in the butt connector. next take the remote coming out of the radio and cut it enough for another butt connector, put a connector on one side and use the extra wire you spliced to the pink and twist it with the remote and connect with that butt connector. boom rear doors work now
Donnie Yukonie
Yates Caretaker
Brian to my Knowledge the 98s and 99s had them I know that for sure , not sure about any previous years
Fishin757
VA Beach
ok so the goal is to get the pink wire (factory harness) and the remote (head unit) connected. get yourself a 4-5 inch piece of wire to act as a jumper between the two. the pink wire will already be connected through the harness adaptor. cut that about 2 inches back from where it goes into the adaptor, go ahead and strip and crimp on a butt connector to one piece of the pink wire.. now take one end of the jumper wire along with the other part of the pink, put them both into the butt connector previously attached to the other part of pink wire.. So far you should have your factory harness with pink wire, butt connector, jumper and pink wires in that order. now all you have to do is the same thing as before but with the remote wire coming out of the head unit. so from the headunit it should be remote wire, butt connector, jumper (the one that was spliced with the pink wire) and other half of the remote. Not trying to sound like a jerk but if you want me to draw a picture i will. im not very good with explaining things
Fishin757
VA Beach
hope this helps
dizhai
