Still all over the road after rebuild and alignment
Squirrelsmith
I changed the ball joints, tie rods, wheel bearings, control arm bushings and it still drives like shit after a professional alignment. There is some play in the steering gear box maybe 1/2" to a inch....
If you let go of the wheel your going into oncoming traffic within 5 seconds but sometimes it likes to go right as well. If there is any imperfection in the road it grabs it hard and follows it. I am constantly correcting. There has been no change with the work i did.
Is there anyone out there who can let go of their steering wheel and their obs just goes straight, Like every other car i have ever driven?
The alignment shop blamed it on the steering suspension design, worn gear box and "oversized" tires 275/55/20
Is a nice straight drive achievable???? or am i just going to waste time and money?
Squirrelsmith
Squirrelsmith
made a slight adjustment in the backlash... tightened my steering box. made a big difference. I may replace it. it still wanders some but its much better
PatDTN
The oversized tires can affect the steering. Also if the wheels are not stock for your vehicle and the offset is wrong it will cause the tramlining you describe. Don't forget the rear axle and checking all mounting components and even tire pressure.
Squirrelsmith
Squirrelsmith
They are wheels off of a 2015 chevy tahoe, pretty damn close. When the guy at the alignment shop said this i figured he was fishing for reasons that didnt have to do with him.
Squirrelsmith
Squirrelsmith
I have considered that the problem may be coming from the rear be it a alignment or even a bad wheel bearing. But my gut feeling is saying its the steering box..... i just dont know yet though. I am determined to track it down though so i will update my progress
east302
Mississippi
The drive quality is all relative, but a straight drive is achievable. Mine’s not too bad, and it doesn’t behave like you described.
I had a bad-out-of-the-box Delco reman steering gear that was dead between 11 and 1 o’clock, it sort of behaved like that and required constant correction.
Your new work included the idler arm/bracket and pitman arm, correct?
Squirrelsmith
Squirrelsmith
I did not do the idler and pitman, I felt they were tight when i checked then and the alignmant shop agreed there was no play
east302
Mississippi
It probably doesn’t matter. If they were the cause of that much slop, I’d think that there would be some obvious movement in the joints when rocking a tire from side to side.
1998Suburban
I was ready to condemn the steering box in mine but the Pitman arm was the real culprit. I checked for play in the old joint on the Pitman and didn't find much until I popped it free. My path was opposite yours. I dropped the steering box & replaced the Pitman first, then moved to the front suspension. In the end she needed everything.
Not sure if it makes a difference but the ball joints may have different tolerances. I used USA made Moog upper & lower ball joints.
fastpat
Upcountry South Carolina
Interesting thread, always love good information. Because we have low traffic in the OBS forums, I'm reviving this thread.
I'm starting on the front suspension replacement, because it wonders a bit. The Yukon has 130k miles on OEM parts. I'm going with all Moog balljoints/parts.
Squirrelsmith
Squirrelsmith
doing idler, pitman, gearbox and replacing the rag joint with a u joint. if i aint driving straight after this i give up
fastpat
The first upper A-arm, the right, arrived today, the rest are due Wednesday. That will be the left upper A-arm and the idler and pitman arms.
fastpat
I think one of the previous commenters may be right, you're running pretty large, heavy tires and wheels. One thing many folks don't add into the calculation is the actual weight of the tires and wheels, not just the overall diameter for speedometer accuracy.
So, you actually installed a new steering box, that's pretty severe. I used to adjust the non-rack and pinion steering boxes for no more than a 1/2 inch of play at the steering wheel. This is why power rack and pinion steering is superior to recirculating ball steering, no play until it's worn out.
I assume that you flushed the whole power steering system hydraulics, including replacing the hoses.
Squirrelsmith
Squirrelsmith
Yeah that was all replaced when i did my poweboost swap. I mean we have to assume that in spite of my heavier wheels this pile can be made to go in a straight line. I have to believe that for my mental health lol
PatDTN
If you decide to go with a U-Joint you need a pair of them ala constant velocity joint. Otherwise you get some really funky effects. If you have a swivel adapter that's like a u-joint in your toolbox try putting an angle on it and twist it and you'll see it speeds up and slows down.
Phlipnstik
