Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I want to put a 2008 steering wheel with controls on my 2001 I have a Z-3 head unit can / will it mount up, and also will / can I get the controls to work?
will it mount tho? and if so would it look ok? mine is ten years old with a lot of Highway miles so long peirods of time with hands on the wheel. also is ther no way to splice the wires to make it work?
I was looking into this... I believe you can get it to work on an aftermarket radio using the 07+ clock spring and wire it up yourself. However I do not believe the airbag plugs are the same.
I've changed my mind on that setup and am either going to run a 03+ base model wheel or get a half leather/wood 01 wheel or a billet wheel.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
