Stabilitrak off when accelerating
PhilThaThrill
Recently I've replaced the motor mounts on my '07 Tahoe. Now whenever i rapidly accelerate the check engine light comes on and it says Stabilitrak Off, Traction Control Off. I'm hoping its unrelated and praying its something simple like a bad wheel bearing or axle rod. Anyone have any ideas?
GMT800 2005 Tahoe Z71
Navy Supporting Member
You need to look at where you did work and checked for damaged wiring at least. This took place after the work you did so it is not uncommon that you may have damaged something.
Welcome to the forum from Oregon.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
Welcome to the Forum from NH.
As PNW stated, please take a close look at the areas where you performed your work. Something as simple as a loose electrical or mechanical connection, or a not-fully-inserted electrical connector, could be causing your issue.
PhilThaThrill
PhilThaThrill
Sorry, new to this.
All connections are firmly inserted and the problem still persists.
Tupapi
