SS Braided Brake Lines
Foggy
KS
Does anyone have a part # or recommendations for new brake lines??
I'd like to replace all 4 caliper hoses with new Braided Lines
Thanks !!
Goodridge is a good brand, don’t have a p/n for your year. Google does.
kbuskill
NE. FL.
Also there are 6 rubber lines on most of these trucks.
One at each caliper and two that go between the axle and frame.
Some only have one between the axle and frame. Can't remember the RPOs for the difference. Just look under your truck to see if you need 5 or 6.
F
Foggy
KS
The only ones I've found so far are the stop tech... I haven't found a full "kit" yet.
Also, they get mixed reviews as the oem brackets will have to be modified
to get everything to fit correctly
So... I might just leave oem lines alone.. I just know that the rubber lines
don't last forever.
I haven't tried calling any of the companies yet for confirmation
FrankU
Babylon New York
Those braided lines don't last forever either. On the Corvette forum there was a guy in Florida driving on a long highway and his braided line gave way. Just a little FWIW
Meccanoble
Georgia
Question, for other cars I changed the lines more for the feeling than reliability of the rubber lines breaking or leaking. Are you guys changing them for the feel or preventative measures. I'm very happy with my braking currently but curious why you guys are going SS.
I did mine for a more solid feel. But I’ve also never had a brake hose fail in 50 years of driving and owning nor has anybody I’ve known. Not saying it doesn’t happen on a rare occasion but there’s plenty of other things that I would worry about more.
F
Foggy
KS
The SS brake lines "tend" to expand and contract less... So yes, you get
a more consistent feel... I figured I would maybe replace mine anyway just
for maint when doing the front brake upgrade.. So that's why I was looking
for the SS braided lines. But I know the an OEM replacement will work fine
and last for many years too. But if the aftermarket ones are a PIA to get
to fit.. then screw it.. the oem repl are cheap enough
TallHoe 96 OBS
