SOLVED Please help, engine runs very poorly!
los341
Hello,
I have a recently acquired 2005 GMC Yukon XL 1500 SLE with a 5.3L flex engine. It's been running poorly ever since I got it. I've been trying (diligently) to figure it out to no avail. I've done so many things to it and nothing has helped. I'm running out of ideas.
Symptoms include:
1. Starts quickly and runs smoothly for a minute or so, but then begins missing and runs terribly. Not driveable.
2. Code P0300
3. Bank 1 long-term fuel trim +10% to +30%
4. Bank 2 long-term fuel trim -10% to -30%
5. Bank 1 old spark plugs are light tan and look burned, as if Bank 1 is running too lean.
6. Bank 2 old spark plugs are black, as if Bank 2 is running too rich.
7. Cylinders 2, 4, 6, 8 (Bank 2) constantly misfiring, with Cylinder 6 being the worst at approximately 150 misfires per minute.
8. Cylinders 1, 3, 5, 7 virtually no misfires.
Here are the things I've done so far:
1. I noticed borderline fuel pressure issues, replaced fuel pump assembly, verified good pressure while running, no change.
2. Replaced all 4 O2 sensors with brand new ones, no change.
3. Electrically confirmed all 4 O2 sensors are wired to the correct pins on the ECU.
4. Electrically confirmed all 8 fuel injectors are wired to the correct ECU pins.
5. Replaced 8 fuel injectors with GM genuine new injectors, no change.
6. Replaced 8 spark plugs and spark plug wires with new, no change.
7. Cylinder compression check (PSI):
1: 184
2: 181
3: 176
4: 180
5: 185
6: 186
7: 179
8: 180
8. Used an oscilloscope to confirm all 8 ignition coils have a similar and good-looking ignition pulse.
9. Removed intake manifold, installed new manifold gaskets and throttle body gasket, also verified no intake blockages in the manifold or heads, no change.
10. Verified no vacuum leaks.
11. Replaced both knock sensors with new, no change.
12. Verified both pre-converter exhaust pressures at O2 sensor holes using an exhaust pressure gauge. Both sides were less than 1 PSI, well below specified maximum of 3 PSI.
13. Verified with stethoscope that all 8 fuel injectors are clicking.
I don't know what else this could possibly be, any help or advice would really be appreciated, thank you!
Carl
Moderator
People's Republic of Colorado
The first clue is that it runs good until the PCM has fuel control -- but we need short term fuel trims. At hot idle, what is the MAF reporting in g/sec (please don't bother posting the value in lb/min; change your scanner settings)?
Graph the upstream O2 sensors to see how they compare and if they're moving appropriately. Age? Mfr? (that's "manufacturer," not mother-f'er...)
What ethanol % fuel is in the tank? What does the scanner say the alcohol % is? (compare)
When was the fuel filter on the rail last changed, if there is one.
While it's warmed up run a CASE relearn if nothing else to rule it out.
Could do an injector balance test.
rockola1971
Indiana (formerly IL)
OP says Fuel pressure good. Id like to know what fuel pressure is at idle and around 2k rpm. Didnt see that the spark plug wires were replaced? How about that braided ground wire running from engine to firewall? Inspect for corrosion at each end and go ahead and clean both ring terminals and connection points with wire brush. Ive seen those braided grounds rot right in half.
L
los341
Thanks Fless, those are some great suggestions. I'll get that information!
Hello,
Symptoms include:
2. Code P0300
1: 184
2: 181
3: 176
4: 180
5: 185
6: 186
7: 179
8: 180
Carl
Timing? I started thinking timing half way through your story. I had plugs like that, bank 1 plugs just getting wrecked, the whole side. I changed the timing sprockets, chain and tensioner- during AFM delete. Of course I changed the camshaft during the build but the lobes fire the same(stock LS1 Pontiac). So the only thing that changed related to the spark is the timing assembly that was changed. It is pretty extensive to accomplish so do your research if I could be on to something before wasting that much time and effort. It worked for my engine.
L
los341
Thanks rockola,
I checked the fuel pressure today. It's rock solid 62psi at any rpm. Also brand new plugs and wires. I took off engine ground wire and cleaned as you said. Also checked for any voltage drop between engine and chassis. It's is practically zero in DC or AC.
L
los341
Thanks DodDel, I'm just curious, since the engine has a single camshaft wouldn't a cam timing issue affect both banks equally?
Thanks, Carl
L
los341
If you STILL have a misfire @ 6, swap that coil with a coil on the other side.
If the fault moves to that cylinder, replace that coil.
Check your electrical grounds. By check, I mean don't be too gentle.
Hello again Marky, per your suggestion I swapped the entire bank 1 set of coils with bank 2. Unfortunately the misfires are on the same side as before. I also removed and cleaned up the engine ground strap. I also verified a good connection and measured a near-zero voltage drop between the engine and the chassis while the engine is running.
L
los341
Hello Fless, thank you again for your suggestions. I tried pulling all 4 oxygen sensors and the engine still runs bad with near continuous misfires on bank 2, especially cylinder 6. I'm just running regular 87 octane fuel with no ethanol. Fuel pump / filter assembly is brand new and verified constant 62psi fuel pressure. I did clear all codes and pulled the battery for a while and it's still doing the same thing.
Any other suggestions are appreciated!
Thank you Carl
rockola1971
Theres quite a few grounds and hots that would cause just 2,4,6,8 problems. The wiring harness to your 2,4,6,8 coils get a ground at splice S157 to G102. Check your black wire at each plug of your coil, check resistance to ground. Should be low at each coil. Also check each pink wire for 12v at each coil plug. All coils are fed power from your INJ2 Fuse and so are your injectors for that side. Your coils are fed via a splice (S160) via the INJ2 Fuse. Check that fuse for 12v both sides to rule out corrosion on the fuse.
Thanks, Carl
Yes, improper engine timing, especially if affecting only one side of the engine, can lead to spark plug fouling on that side, but other factors like fuel mixture, ignition system issues, or even coolant leaks can also contribute.
bodabdan
Is there any chance you have a leaking exhaust/broken exhaust manifold bolts?
L
los341
Problem Solved! I figured out what was wrong! In my original post, I mentioned that I checked the pre-cat exhaust pressure as less than 1 PSI. When first I checked it, I had to hook it up to the O2 Sensor 1 hole (pre-cat) on each side. Since the gauge hose wasn't long enough for me to see it while in the driver's seat, I had to start the car and then get out and get under the car to look at the gauge, which would read about 1 PSI. I did this several months ago.
Recently, I was thinking about this and decided to go back and check my work. This time, instead of starting the car and then getting underneath to look at the gauge, I had my wife start the car while I watched the gauge. It was connected to Bank 2 Sensor 1 port. To my complete amazement, the gauge started at zero and went ALL THE WAY AROUND PAST 8 PSI, but kept going around the bottom before finally setting on 1!!!!!
So yeah, it read 1, but the real pressure was probably at least 12PSI.
Hmmm, Houston, we have a problem.
I cut the cats open, removed the cores, welded it back shut, and now it runs great! I noticed that Bank 2 cat was black, while Bank 1 cat was white.
Why did bank 2 cat go bad? Well, when replacing the fuel injectors earlier, I noticed that Injector 6 (bank 2) pintle cap was half hanging off, but still attached on one side. So it was hanging at a diagonal, potentially interfering with the injector's spray pattern. So my best theory is that fuel droplets were forming and dripping off the pintle cap. These droplets would theoretically not burn correctly or completely, sending some raw fuel into cat 2, causing it to overheat, melt, and clog.
Has anyone else ever had something like this happen?
Carl
Po-B0b Auto Tech
Hello,
Symptoms include:
2. Code P0300
1: 184
2: 181
3: 176
4: 180
5: 185
6: 186
7: 179
8: 180
Carl
Hello, I'm sure if you solved your poor running condition as of yet. If you haven't I would pull the fuel rail alone with the fuel injectors to ensure they aren't clogged. Please let me know what you find.
General Fodder
