[SOLVED] 4Lo 1st gear
Mudsport96
40.923,-89.488. Illinois
What you could do, is have a friend lay with their head under the vehicle. And with the engine off, and parking brake set. Turn the key to on but dont start. Then run the shifter through all the gears. Your statement of it seems like it starts in a different gear when in the first position, sounds like a 2nd gear start. It is possible that the shifter shows 1st, but is really only getting to 2nd on the transmission linkage.
mountie
Make sure you both have 6 drinks first. :)
B
BPSmith
Problem Solved: I eventually took it to a Chevy dealer I trust and they did a proper scan and transmission disassembly to determine I had burned up the transmission’s clutch breaks or engine clutch (not sure the proper terminology). I had the transmission replaced with a beefier model that better suits my off road needs. I was also advised to use my breaks a bit more when in Low Range and descending steep grades so I spend more money on replacing break pads vs transmissions! Thank you all for your insight and helpful guidance.
Marky Dissod
Unfortunately, thought of another possibility ...
Other possibility is that you've worn out/used up your 1st gear's overrun clutches.
If so, that'd need a repair/replacement; transmission would need to come out.
Problem Solved: I eventually took it to a Chevy dealer I trust and they did a proper scan and transmission disassembly to determine:
Proper terminology is 'overrun clutches'.
Tupapi
