03GMCYukonXL
- Joined
- Mar 19, 2023
- Posts
- 149
- Reaction score
- 119
Ok so I have a 2004 Tahoe Z71. So here is the story. It shifted fine but had some clogged cats and a knock sensor code. It had no acceleration and could barley make it up a steep hill. I replaced the knock sensors and the cats. It drove ok and then it just started revving ALLLL the way up to 6k rpms in first unless you let off the gas. If you let off the gas, it'll shift to second but always puts it at around 2k rpms. It won't go past 2,200 rpms in second but pulls just fine. Even going up a hill. It want's to shift back to first at lower speeds. It acts fine otherwise. If I'm doing highway driving it acts fine.
Now if I stay at low speeds, like 3k rpms or lower, the truck will shift into 2nd gear just fine. It's only when I gun it that I have to let off. I thought maybe the knock sensor was preventing it from going over 2,200 rpms in second or maybe there is a reset. However that is not the case. I'm thinking about trying to change the shift solenoids. I'm here to get any other opinions on what this may be. It really doesn't seem like the transmission at all. It showed no signs of slippage or anything irregular whatsoever before this.
