Show off your 2015+ leveled Tahoes and Yukons!
gat0r
DFW
langston1726
Just posting this from about a month back. Will try to get more pictures later.
2015 Yukon SLT
Rear: Blistein 5160 with the Moog springs and 1.5” lift spacer
Adjustable sway bar links
front: Rough country UCA
bilstein 6112 adjustable coil overs with springs and small top out spacer to level it out.
295/55/20 nitto ridge grapplers.
Down the road I’d like to upgrade the front coil overs to Fox or King with dirt king UCA. But that’s for later on.
How do you like the 6112s? Looking putting some on my wife’s 18 Yukon SLT. These stock shocks are junk.
Trustee
2018 Tahoe 4x4, 1,5" Suspension Maxx Level, Method 305NV, Toyo RT 285/70 R17. No rubbing issues.
Hunter Linn
Tuscaloosa, Alabama
I’m a big fan of them. It’s a great economic decision if you want semi-Off-road coilovers. They come with the springs so the ride is slightly firmer but it feels more controlled.
nick14226
A few mods since page 54. For a summer setup went with 305 45 22 Nitto Ridge Grapplers on satin black 22x9 snowflakes I had from a previous setup. Painted the calipers red, power stop drilled and slotted rotor kit, and 1.25” bora wheels spacers. Wheels have a +31mm offset so puts them around 0 with the spacers. Thanks to dwsmoot for pics and details on wheels, tires, and spacers. Extremely helpful with what would work. Rear of front wheel wells did need some minor persuasion to clear this setup. Here are some pics.
GTNator
Senior Member
Looks awesome, like the dark knight.
langston1726
Looks great. Is that a graphite edition or did you black all the window trim out?
nick14226
Couple more pics to show the spacers and area that needed trimming in the wheel well. Not sure if it has come up before, but be careful on the passenger side if you’re in there with a cut off wheel and hammer, there’s a tube (assuming it’s for the rear AC) that’s not too far from where you’re working.
Joey Justice
Flat Rock, NC
This is the best thread ever, it took me 2 hours to read through everything. I have a 2017 Suburban and would like to go 10" wide with -25 offset and 285/55/20 tires. Anybody tried this?
nick14226
That’s the size wheel I ran on my f-150 with a 6” lift and 35x12.5’s. Looks great, but added fender flares, they were out there a ways. You’re talking a much narrower tire so that could help, but I think you’ll need more than a level to clear that offset when turning. Came across a Yukon on a different site running 20x10’s and 285’s, don’t recall the height, but they had a budget fabtech lift to clear them (raises front 3.5 or 4”, seems to vary).
gat0r
DFW
sort of... 22x10 w/ -25, except im lowered
running 305/45-22
Puckett88
Installed SuspensionMaxx level kit. 1.75" front. Installed 33x12.5R22 Nitto Ridge Grappler. Also, Plasti Dip black the chrome inserts on the rims. Little bit of rubbing on full turn but not a big deal. Need to figure out what I need to trim. Definitely love the look and how it rides now.
View attachment 210648 View attachment 210649 View attachment 210650 View attachment 210651 View attachment 210652
Truck looks great! Would you mind posting a photo of your denali from the side? I am debating on whether to go with 1.75" or 2" level from SuspensionMaxx on my 2020 Yukon Graphite Performance edition. I definitely do not want to be nose high and was already thinking that 1.75" was the way to go.
nick14226
If you go back a page I have a side view of my Yukon with a 2” RC. It’s black with vinyl wrapped chrome so looks like a graphite. It measures out 1/4” higher in the rear, wheel well to ground.Have to imagine with the extra weight of the 6.2 in the front, and assuming different springs aren’t used than on my 5.3, you’d be very safe that the nose wouldn’t be high on yours.
Puckett88
Ended up going with the 1 3/4" suspension maxx level kit and it came out perfect.
NjA4207
