Show off your 2015+ leveled Tahoes and Yukons!
mikeb3408
Thanks for all the info on this thread which helped me decide on what I wanted to do.
I had the following installed yesterday, very happy with it:
  • 2" Rough Country Front Level
  • Tow Hooks
  • PPV Air Dam
  • Chrome Eyebrow Trim over fog lights
View attachment 242305 View attachment 242306
If I did eventually go to a different tire what are some recommendations? What size can I go to without having any rubbing issues at all?
Or should I stick with stock size?
GreyStone
275/65/18 will not rub at all - you might be able to get away with 265/70/18 ---this would be 1 inch bigger diameter than what you have now.
AH64Medic
South Carolina
Here’s my 2017 4x4 with a 1.5” front spacer and 275/70/18.
AH64Medic
South Carolina
Looks amazing - do you have any rub on U-turns?
I actually just got them on yesterday and I haven’t done a tight u turn yet. I’ll let you know after I do one. I love how I don’t have to worry about ripping off the air dam when I pull into a parking space now.
Ccarterz71
I have 5100’s on all 4 corners. I know exactly what you’re talking about. I have the fronts all the way up. I run 285/50/22’s with no issues.
The pot hole wheel hop has completely been removed with the shocks. They are firmer but you feel the road, no more butter ride or floating. When coming into our driveway with stock shocks the Yukon would bounce another 20 ft after the curb. Not the case anymore.
Handling has improved dramatically and off-road/dirt roads in GA ride like paved ones. I recommend them although I am no suspension expert.
Andrew Hastings
Just finished bulding my Tahoe....
2017 Z71 Tahoe
4" TUFF COUNTRY LIFT
FABTECH CONTROL ARMS
20" VENOMREX VR-602 GRAPHITE
34" ROADONE CAVALRY M/T
PEDAL COMMANDER
S&B COLD AIR INTAKE
INSTAGRAM @lonestarautogroup
have some light bars I want to mount inside the grill. If anyone has some details on ways to mount them please hit me up!
GreyStone
2017 Z71 Tahoe
PEDAL COMMANDER
S&B COLD AIR INTAKE
have some light bars I want to mount inside the grill. If anyone has some details on ways to mount them please hit me up!View attachment 242574 View attachment 242575 View attachment 242576 View attachment 242577
Sweet Ride!....you using the factory gear set?
BourbonNcigars
2017 Z71 Tahoe
PEDAL COMMANDER
S&B COLD AIR INTAKE
Love the way it looks.
I'm a previous Pedal Commander owner. People who never had one talk shit. I would buy one again if I was unsatisfied with the current vehicle's throttle response. They're awesome.
olyelr
Elk Rapids, MI
2017 Z71 Tahoe
PEDAL COMMANDER
S&B COLD AIR INTAKE
What size rubber is that? 275/65/20? Such a good stance!
olyelr
Elk Rapids, MI
SuspensionMaxx. Autoride still works as it should and the front rides a million times better with the 5100s.
Gotchya. I put fox units up front of my wifes denali and deleted the magnaride. Now the back shocks seem to be shot so gonna replace them. I like the leveling feature and think I want to put the original shock setup because of it. Wouldnt mind adding a little spacer since the front is up more than I want.
Hunter Linn
Tuscaloosa, Alabama
Just posting this from about a month back. Will try to get more pictures later.
2015 Yukon SLT
Rear: Blistein 5160 with the Moog springs and 1.5” lift spacer
Adjustable sway bar links
front: Rough country UCA
bilstein 6112 adjustable coil overs with springs and small top out spacer to level it out.
295/55/20 nitto ridge grapplers.
Down the road I’d like to upgrade the front coil overs to Fox or King with dirt king UCA. But that’s for later on.
Andrew Hastings
Spot on man. Trying to find people who have installed light bars inside the grill but haven't had any luck. Tires only rub slightly if I'm turning going up steep inclines
Merch619
