Show off your 2015+ leveled Tahoes and Yukons!
langston1726
The wife’s 2018 Yukon
2” level with 285/70/17 BFG KO2s on some 17x8.5 Method Racing 305 NVs
Planning on either color matching or replacing the grille with a blacked out Denali grille.
olyelr
Elk Rapids, MI
Lookin good!
I vote color match the chrome grill, and leave the inserts black.
cireallin
cireallin
if you're going to get new shocks anyways, I'd invest in shocks that accommodate the 1.5" lift in the rear. After I put the 2" in the rear, I can tell it needs a longer shock. I know rough country sells one that is for 0-2.5" of lift.
You might want to check out the shock re-positioning bracket that SuspensionMaxx sells. I just came across it today actually. I am adding them to my current setup.
Here's a link:
https://suspensionmaxx.com/product/SMX-16915ext
wjburken
Eastern Iowa
Here's a link:
Quick question.
How does this extend the shock without folding over on itself? Am I missing something or won't this just pivot on the bolt that goes through the end of the shock absorber?
cireallin
Quick question.
It's my understanding it places the mount of the shock on a different angle, so the overall travel is corrected with the leveling kit spacers installed.
cireallin
Have you found a decent blacked out Denali grill? All of the ones I have seen are honeycomb style and call it Denali, but the grill on my new Denali has straight flat pieces, not holes cut out. Curious what you've been looking at for yours?
langston1726
Looking at this one. I haven’t seen any aftermarket grilles that aren’t the “Denali” style. This is almost the same price as an OEM though. That’s why I’m leaning towards just color matching this one.
FatDog
Well......another update.
Trimmed the piece on the mudflap and it worked but then I got to looking and measuring and then comparing to others with the 2" level lift. After looking at a ton of different pictures and comparing, I'm going to throw in two spacers from the Suspension Maxx Kit and raise the front from 1.5" to 2" and see what she looks like. When I'm done, I'll post up pics and see what you guys think.
olyelr
Elk Rapids, MI
I would recommend putting a floor jack under the front and jacking it up a half inch, then step back and take a look.
“Just tossing the spacers in there” is a lot of work to realize you dont like it.
sspearsau
For those that are running the Bilstein 5100s, I am looking to go this route as well for my wife. We just got a new to her 2018 Tahoe LT with 20K miles on it (this is actually my first post having been a lurker up to this point). This is our first GM vehicle. The ride is very loose when turning, or making a swerve around a pot hole, but it also seems to hit pretty hard when contact is actually made with a pothole.
Two upgrades I am looking at are doing a sway bar and replacing the stock suspension with the Bilsteins to hopefully improve the overall ride on an otherwise great car. I would also take the opportunity to level her out as well.
Have there been any gripes with the Bilsteins making the ride "too rough" or is there really no comparison to the stock ride with the Bilsteins being a no-brainer?
Thank you in advance!
GreyStone
cireallin
Oh yea, forgot about that one. I am still hunting one that is black in the middle and has the chrome ring around the outside. The only option I've seen so far is the one from Putco but I am considering having mine painted black instead. Anyone else gone that route?
Tahoe14
Central Fl
sspearsau, I would contact NORCALSS who is a suspension vendor on this forum. He has a lot of knowledge and would be able to help you. Good luck.
ScottS-Michigan
