Shopping for wheels-I need a bit of guidance from those more experienced
Mighty Hd
Florida
As the title says, I’m shopping for some new wheels And need a bit of guidance as there seems to be quite a bit of misinformation.
I have a 2013 Tahoe Z 71 four-wheel-drive, currently has a zone 2 inch front leveling kit with Bilstein 5100 struts set at the factory height. I do have a CCM 2 1/2 inch strut spacer to swap out in case I need the extra half inch.
I have a new set of Goodyear Dura trac 285/65r18 that I’d really like to keep instead of buying another set of tire
s.
With a 2 inch or 2 1/2 inch lift with an 18 inch wheel — what is the widest offset/backspacing that I can go with? I have the front fender liner zip tied back on the front and no modifications to the rear portion of the wheel well liner.
Looking at the following wheels. (The links are not for the right Sizes but to give you an idea of what they look like)
XD heist 18x9 black milled
https://www.kmcwheels.com/product/wheels/xd818-heist/?attribute_pa_finish=satin-black-milled
On a suburban:
https://www.google.com/imgres?imgur...2ahUKEwid2p6PzeThAhXGGlMKHZb0CxUQMygfegQIARA7
Black rhino sierra milled 18 x 9
https://www.discounttiredirect.com/buy-wheels/black-rhino-sierra/p/75783
I can’t seem to find any of these on a 2008 to 13 body style
https://www.extremecustoms.com/realview-vehicle.php?c=18391&v=1
Helo HE901
& HE978
Big Mama
Virginia
Have you tried the tire size calculator? It has an option for wheel offset too.
Big Mama
Virginia
Just go by the stock size and offset as a start then you can play with the numbers. If you really want to be sure befispending big bucks go to a used tire shop and get one mounted.
FoghrnLeghrn
Do you want to stay close to factory or do you want the tire moved out from the wheel well?
M
Mighty Hd
Florida
I would like them moved out a bit ...if possible. I'm seeing 18x9 and 20x9 with anywhere from 1mm to 18mm offset that seem to fit?
M
Mighty Hd
Florida
Has anyone installed RST wheels or Midnight Edition wheels from the 18-19 Tahoe's??
4OFFSHR
CA.
Fuel, BlackRhino, Method Race wheels, all of them offer their wheels in an offset range for factory and leveled or lifted trucks. Since you want to keep your new 18" tires, you should have no problem getting the right fit from any of those suppliers...keep in mind too that the rim width aftermarket is going to be wider than stock, stock I think is 8.0 or 8.5, and the aftermarket will range in 8.5-9.0 with offsets from -12 to +18. Anything from a 0 to +12 should be fairly aggressive and will look right with your current tire setup.
sanco
Chicago
I just put on a 1mm offset fuel vector 18" wheels with duratrac OEM midnight edition width tires (265 i believe). I have very slight rub in reverse at turn without any suspension or bumper modifications. I think I would be able to do a 285 tire with just ziptying the wheel well
MD Tahoe 13
Any recommendations on where to buy OEM 17 inch rims for 2007-2014 Tahoes or Suburbans? Looking for four. Leery about buying off eBay.
sanco
Chicago
MD Tahoe 13
craigslist, facebook marketplace, letgo, offer up are all good. I had mostly good experiences there. If youre lucky on this site's classifieds section there are great deals from time to time
theres one right now for police wheels
https://www.tahoeyukonforum.com/threads/black-police-wheels-with-chrome-center-caps.111853/
GM wheels will have a GM stamp on the inside of the wheel. Look for bends and cracks or signs someone was trying to fix them
Thanks I will look there. I have an SSV with police wheels that I'll likely try to sell here or elsewhere when I buy the new ones.
Conedaddy
